Author Topic: IBM Model F replacement springs  (Read 1854 times)
Offline geekhackuser
« on: Mon, 13 February 2017, 03:34:03 »
Help need folks.
Just go an IBM Model F XT and a few of the keys feel a bit "off" as in I dont think the spring is buckling properly etc.
Is there a place where i can get replacement springs?  or try to fix so its sounds a bit more pingy or buckling? my guess is the springs are out... I think...
Re: IBM Model F replacement springs
« Reply #1 on: Mon, 13 February 2017, 08:13:20 »
Replacing springs is quite tricky.
More likely, the key stems are not seated properly in the barrels. Pull them out and re-seat them. Sometimes it takes multiple tries, and it may help to stand the keyboard up on edge (front or back) so that the springs flop forward or back when you re-insert the stem.
- D Trump 2026-10-24
