Author Topic: What Unicomp looks like  (Read 5465 times)
Offline ander
  • I type, therefore I am
« on: Mon, 13 February 2017, 03:50:25 »
Ever wonder what Unicomp, our favorite current manufacturer of genuine buckling-spring keyboards, looks like down there in Lexington, Kentucky?
Tonight it occurred to me that we could at least see it from the outside, courtesy of Google Maps.
From the air, you can see it's a pretty big place:
160301-0
Of course it was built to accommodate IBM's volume of keyboard production, so it's hard to say how much of it Unicomp actually uses. But it probably takes about the same amount of space to make a BS board as it always has.
160303-1
Literally millions of keyboards were loaded up along that rail siding over the years (including some particularly pulse-quickening ones, LOL).
Approaching from the street:
160305-2
160307-3
160309-4
160311-5
Wonder if you can walk in, order a keyboard, and have them make it for you on the spot? It'd be fun to try.
Offline Tom_Kazansky
  • Oblivion Knight
Re: What Unicomp looks like
« Reply #1 on: Mon, 13 February 2017, 03:58:21 »
I doubt it  :p , if you can then the hospitality level is too d@mn high  :))
have a tour around the factory will be nice, I guess.  ;D
« Last Edit: Mon, 13 February 2017, 04:00:46 by Tom_Kazansky »
Offline Entropia
« Reply #2 on: Mon, 13 February 2017, 05:08:05 »
I expected the building front to be full of bulges and painting defects... and with the Unicomp sign off-centered.
Offline alh84001
« Reply #3 on: Mon, 13 February 2017, 09:42:23 »
It's funny to see how it's fully surrounded with residential houses. I wonder what the surroundings looked like 20, 30 years ago.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Mon, 13 February 2017, 10:46:50 »
Has anyone here ever actually visited them? I know some of them live very close by.
Offline ander
« Reply #5 on: Mon, 13 February 2017, 18:30:50 »
Aw, they're not that bad... But I wouldn't be surprised if the building creaked a bit.  :?)
I doubt it... have a tour around the factory will be nice, I guess.
Imagine the aroma of bubbling ABS drifting through the neighborhood on a fine spring afternoon... I wonder what dye-sublimation smells like?
« Reply #6 on: Mon, 13 February 2017, 19:02:02 »
PBT not ABS
Offline ander
« Reply #7 on: Wed, 15 March 2017, 17:59:29 »
PBT not ABS
I was going by what czarek said here:
...Old IBM cases are made from PVC which I think is no longer allowed to be used in keyboards, new Unicomp cases are made from ABS...
...though Esteemed Elder ch_123 also said:
IIRC, Unicomp cases are made of a blend of ABS and PVC...
In any case, whatever they use, you can bet it's got a pungent aroma.
« Last Edit: Wed, 15 March 2017, 18:01:43 by ander »
« Reply #8 on: Wed, 15 March 2017, 18:21:48 »
PBT not ABS
You referenced dye-sublimatiom in the post I replied to...you don't dyesub a case you dyesub keycaps and you don't dyesub abs you dyesub pbt.
Offline chyros
  • a.k.a. Thomas
« Reply #9 on: Wed, 15 March 2017, 19:35:36 »
PBT not ABS
Dell cases were dyesubbed AFAIK.
« Reply #10 on: Wed, 07 June 2017, 23:05:17 »
That's what the outside looks like.
What about the inside?
Offline klennkellon
  • I like bottoming out
« Reply #11 on: Thu, 08 June 2017, 03:03:37 »
It would be like Subway except keyboards instead of sandwiches.
Offline SBJ
  • Tactile pls
« Reply #12 on: Thu, 08 June 2017, 07:36:44 »
Yeah, that's what I was most interested in.
Would love a tour of the place if I ever get a chance to revisit the US of A.
