Author Topic: Using a keyboard without a case?  (Read 8608 times)
Offline snarfarlarkus
« on: Wed, 15 February 2017, 01:13:52 »
So I'm using my GH60 and decided to take off the plastic case to see how much of an effect it would make. And to my surprise the keyboard without the plastic case feels so much better. When I bottom out now, it doesn't make that thunky hollow plasticy sound it now just sounds like the keycaps hitting the metal plate.
Now I do want to try an aluminum or wood case such as the lambo 60% to see if it would make my keystrokes feel better but I'm enjoying no case far too much.
I just wanted to ask, is it safe to use a keyboard in the long run without a case? The bottom of the pcb is exposed and I don't know too much about pcbs so I don't want to damage it in any way. So if anyone could confirm with me if it does damage the pcb or not that would be much appreciated thank you!
Offline happylacquer
  • BS Apologist
    • BHOBuds
Re: Using a keyboard without a case?
« Reply #1 on: Wed, 15 February 2017, 01:18:03 »
At least use a piece of foam from a motherboard?!
Offline merlin64
    • MechMerlin
« Reply #2 on: Wed, 15 February 2017, 01:33:35 »
Wow, isn't that a little bit shaky?
I've seen some people use rubber feet where the standoffs of the case go in. That might be a better solution
« Reply #3 on: Wed, 15 February 2017, 01:38:59 »
What do you mean by piece of foam from a motherboard? My motherboard has no foam? Sorry I may be missing something here haha.
Yes, the only downside to this is the shakyness. Its not very stable but man it feels and sounds so much nicer than in that plastic case haha.
And sorry but where are the standoffs? I don't see any on my GH60 pcb?
Offline merlin64
    • MechMerlin
« Reply #4 on: Wed, 15 February 2017, 03:21:33 »
You are correct. If you look at the case, you'll see that there are holes where the screws go in. I'm talking about those. Maybe standoffs is the wrong term
But I've seen some people put rubber feet where the screws go in, and instead of screwing into the case, they screw into a rubber foot. I hope that's descriptive enough.
« Reply #5 on: Wed, 15 February 2017, 03:32:09 »
I get what you're saying but I still don't see any holes on my PCB There doesn't seem to be any holes at all that I can screw them into. I would love a solution to stop this shakyness of the board, I even prefer the look without a case to be complely honest haha. I just cringe when I move the board across my desk mat because I can hear and feel all those soldering points rubbing against my mat and it doesn't feel or sound nice at all haha.
  • BS Apologist
    • BHOBuds
« Reply #6 on: Wed, 15 February 2017, 03:32:29 »
It is just anti static foam. Would prevent anything on bottom from being damaged. something like this always comes under mobos when you buy a new one, so if you built a machine ever you might have one
Offline stoic-lemon
« Reply #7 on: Wed, 15 February 2017, 04:21:54 »
Surely your PCB must have holes or you wouldn't have been able to use it with a case.
« Reply #8 on: Wed, 15 February 2017, 07:08:18 »
IBM Model F 122-key terminal without the top case shell. The bottom pan is integral.
- D Trump 2026-10-24
Offline TalkingTree
    • My projects
« Reply #9 on: Wed, 15 February 2017, 07:12:56 »
If I were you, I would get a piece of plain polycarbonate, drills holes for standoffs and secure the PCB on it.
Offline Sneaky Potato
  • Gunslinger
« Reply #10 on: Wed, 15 February 2017, 08:27:27 »
This is actually pretty cool.
Offline rmendis
  • Artisan addict
« Reply #11 on: Wed, 15 February 2017, 08:32:50 »
This looks sick!
« Reply #12 on: Wed, 15 February 2017, 17:46:23 »
THanks guys. I think what I will do i
« Reply #13 on: Wed, 15 February 2017, 17:49:24 »
Thanks guys. I now know what holes you are talking about! Stupid of me, I thought I couldn't drill into them because they're part of the PCB but now I realised they were used for the acrylic case.
Any recommendations on some foot metal feet? I've seen the cone shaped ones that just ended on massdrop?
« Reply #14 on: Thu, 16 February 2017, 17:09:26 »
Also anyone know of a good case? Want something that'll make the keystrokes feel better?
« Reply #15 on: Thu, 16 February 2017, 17:25:44 »
« Reply #16 on: Thu, 16 February 2017, 17:35:13 »
There are always my mats:
https://geekhack.org/index.php?topic=59308.msg1359377#msg1359377
I use these on both my home and work daily drivers. :thumb:
« Reply #17 on: Thu, 16 February 2017, 17:40:01 »
DId they add to the feel of the keyboard at all? Or just sound dampening?
Offline Andy_Nixeus
  • * Commercial Vendor
    • Nixeus Tech, Inc.
« Reply #18 on: Fri, 17 February 2017, 13:38:13 »
Looks very cool and technological haha
I am here to help. So let me help ! =D
« Reply #19 on: Fri, 17 February 2017, 15:26:04 »
it's possible, but i think it's too minimalist even for my tastes
i would say get a clear acryl case made because they look cool and mitigate a lot of the issues that come with not using a case
Offline y11971alex
  • Looking for Toronto meetup
« Reply #20 on: Sat, 18 February 2017, 13:47:02 »
Possible.
