Author Topic: [de] Strange IBM Terminal (?) kb  (Read 2838 times)
Offline Mental Hobbit
« on: Thu, 04 February 2010, 11:51:47 »
This looks like some common 122-key IBM Terminal. 1390888 appears to be an IBM type number too. But the label doesn't look like IBM. "Made in the Netherlands", uhm?
Seller's description says: "Unfortunately I couldn't test the kb, as I don't have a PS2 adapter. According to my neighbor it works though."
Very illuminative ;)
I guess a PS2 adapter won't help with this specimen?
Typing on blues.
Offline ch_123
« Reply #1 on: Thu, 04 February 2010, 12:21:38 »
That's an IBM terminal keyboard alright. Note the IBM logo on the top right hand corner.
As for the "Made in Netherlands" bit, I'd bet it's been refurbished by a Dutch repairer.
It's a 3179 terminal keyboard apparently. Might be adaptable with aid of a PS/2 cable swap.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2 on: Thu, 04 February 2010, 12:29:04 »
3179 = same non-AT/XT compatible DIN plug as my 1386887s had. Yes, it can be converted using the current cable swap method.
Worth noting: my recommended conversion method is going to become the ATmega32-based controller currently popular in Modifications once mine is built (assuming I have considerable success with it).
kishy.ca
« Reply #3 on: Thu, 04 February 2010, 12:35:51 »
Cable swap method - are you saying just cutting off the plug of the existing cable and soldering on a PS2 plug would be sufficient?
Typing on blues.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #4 on: Thu, 04 February 2010, 12:40:50 »
Quote from: Mental Hobbit;156253
Without meaning to be rude, there has been a gigantic, highly detailed thread about this around for quite a while (it was the reason I registered here in fact).
That said, it is gigantic, so...
Yes, replacing the cable (since the original is quite short) gets you basic functionality, basically like a quirky Model F AT. Throw some jumpers on some pins inside (see the thread) and you get a marginally better level of operation (or no change, depends on how good it was to start). Swap a driver (Win2k/XP) and you've got even better functionality.
Then you've got to remap the keys, but most members here have a method for doing that already. It starts out almost exactly like an AT Model F from a layout perspective.
Note: links to relevant content are in my signature.
kishy.ca
