Author Topic: Pok3r RGB with BBB Acrylic Case and Diffuser?  (Read 2354 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« on: Fri, 17 February 2017, 13:30:39 »
Is it compatible? If so, which version should I get? Also, would the built in RBG LEDs be enough to light the bottom or would I need to buy a kit to install below the board?
I am trying to do something like this:
Offline lucifiel
Re: Pok3r RGB with BBB Acrylic Case and Diffuser?
« Reply #1 on: Tue, 14 March 2017, 16:24:18 »
I don't think the Poker PCB has the in built RGB SMD RGBs that are on the underside of the PCB?
I thought they were just for the inswitch LEDS?
In any case, the BBB case doesn't mount like normal Poker cases, there are holes on the sides of the PCB.
If you want to go for that look, you might as well just buy the PCB from Winkeyless as well, they're really nice!
