Author Topic: How do SwitchTop and Originative Springs compare?  (Read 2390 times)
Offline ArchDill
« on: Sun, 19 February 2017, 02:48:53 »
Originative is out of the 62g springs so I bought some from Switch Top. Is there really a difference? I only needed 20 more but I have a friend that has been looking for some and can not get any offers. So I figured that I would just order a new set since I barely had enough for even the alphas.
Offline klennkellon
  • I like bottoming out
Re: How do SwitchTop and Originative Springs compare?
« Reply #1 on: Sun, 19 February 2017, 03:27:56 »
Springs are springs. Both should be about the same. Any difference would be really small.
Offline ArchDill
« Reply #2 on: Sun, 19 February 2017, 13:14:09 »
Ok, that is what I was thinking. Thanks!
Offline klennkellon
« Reply #3 on: Sun, 19 February 2017, 16:54:31 »
Just don't waste your money on gold plated springs. They're actually worse than regular springs because the gold plating can fall off over time.
Offline ArchDill
« Reply #4 on: Sun, 19 February 2017, 16:58:18 »
My only gold spring experience was pretty bad. I prefer the silver. People say there is no difference but my 62g S have more spring back than my Sprit 67g gold.
Offline klennkellon
« Reply #5 on: Sun, 19 February 2017, 17:03:19 »
I only got gold springs for my ergo-clears cause I didn't wanna wait another week for the stainless ones to come back in stock.
