Author Topic: How to find/make lubing station?  (Read 3969 times)
Offline Damonskv
« on: Mon, 20 February 2017, 07:11:00 »
Tried to find on the website the CAD files that will allow me to do something like this:
http://www.kbdmania.net/xe/index.php?mid=photo&page=15&document_srl=5942678
All that has just found some old IC
Does anyone know where to buy or even better where to find CAD files?
Offline Damonskv
Re: How to find/make lubing station?
« Reply #1 on: Mon, 13 March 2017, 05:48:32 »
bump
Offline wodan
« Reply #2 on: Mon, 13 March 2017, 06:05:11 »
Just make your own CAD file with olkb and swilkb:
https://deskthority.net/workshop-f7/homemade-mod-lube-station-for-mx-alps-switches-t14799.html
Modded more than 2000 switches with this one I made and it's still in good condition ;)
Offline Damonskv
« Reply #3 on: Mon, 13 March 2017, 06:52:45 »
Thanks, probably will do so. I have no experience in switch lubing, and I think there is some value depth of the station and the number of layers. And here are the dimensions of holes for the second and subsequent layers is not so easy to determine.
Offline Blackhawk
« Reply #4 on: Mon, 13 March 2017, 07:00:47 »
I came across this .dwg file some time ago, maybe it can help you out
http://kbdlab.co.kr/index.php?mid=board_tune&document_srl=3879005
Offline Damonskv
« Reply #5 on: Mon, 13 March 2017, 07:06:54 »
Thank you very much  :thumb:
