Author Topic: Hey from France !  (Read 2218 times)
Offline galakcy
Hey from France !
« on: Mon, 20 February 2017, 09:59:04 »
Hello Guys  !
I 've been watching  here for a while (like the other new guys here ! :p ) and it's time to me to introduce myself ! So i'm french, 23, working in IT since two years. I 'm a casual gamer.
And a little note : i start ( to practice) in english langage, and i want to improve my skill, but for now i 'm just a beginner , so forgive my little mistake and you can correct me when you want.
I started with a  ISO fr  Razer Blackwidow Chroma with kailh blue, before to know the "Masterrace Mechanical KeyBoard " .  That was a good start for me , but too "clicky" for my girlfriend ! and too weak !
Then and for now , i have a  ISO fr Ducky Shine 5 RGB , with cherry MX red. I'm really happy with it, it's a very good keyboard, but i think the mX red is too light for me. But enough good for my use.
I just order today a Leopold FC750R (Ainsi  US)  and a Leopold FC210TP  (yes i play with the numpad, i'm left handed :/ ) in MX brown ; I really want to try the Ainsi format (i always typing in ISO FR) and i think Leopold is a good brand !
I'm in love with the possibility to customise keyboard with keyset, artisanal keycap, etc.  Soooo yes , i'm rellay afraid to spend a lot of money in Artisanal keycap, keyset , etc
I also ordered the  GMK Plum Custom Keycap Set  on MassDrop , and now waiting to receive it ( in june 2017 ! Arg !)
Well i think it's good for me here !
See you later ;)
Offline sek1ne
  • Sek-eye-n
Re: Hey from France !
« Reply #1 on: Mon, 20 February 2017, 10:27:10 »
Welcome to the site! If you are worried about spending a lot of money on artisans the best way to do it is to wait for raffles as that is usually the cheapest way to get your hands on them. The aftermarket can be a bit ridiculous.
Biking is fun.
Offline galakcy
« Reply #2 on: Mon, 20 February 2017, 10:41:35 »
thanks    @sek1ne !
Well, that a pretty good advice, i will see that ;)
Offline decker
« Reply #3 on: Mon, 20 February 2017, 11:01:58 »
Bienvenue,
Moi, j'ai craqué pour un Whitefox en ISO - Cherry MX rouge.
Par contre faut que je commande des touches Azerty, j'en ai uniquement trouvé chez WASDkeyboard.
Je dois finir le fichier .SVG de disposition personnalisée et ensuite je commande !
A+
Offline galakcy
« Reply #4 on: Mon, 20 February 2017, 12:35:16 »
Hey @decker !
Ho oui, j'ai deja vu le whitefox plusieurs fois, il est trop beau !
Peut pas t'aider pour les touches AZERTY, moi non plus je n'en ai pas trouvé (enfin du moins des touches sympa).
Connais pas trop WASDkeyboard , j’espère que tu auras une bonne expérience avec  (PBT ou ABS ? );) .
J'ai perdu espoir  avec l'ISO fr (pour trouver de bon keyset), du coup je passe sur de l'AINSI, j’espère m'y faire assez vite.
Offline galakcy
« Reply #5 on: Mon, 20 February 2017, 13:48:45 »
here is some pictures of my ducky Shine 5 :)
With a custom Keyset ( but not good as i want ! bad ABS :/ )
