Author Topic: [HELP] KBD75 Stabilizer vs Plate ISSUE  (Read 7167 times)
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« on: Thu, 23 February 2017, 23:33:34 »
So I recently acquired a KBD75 keyboard from KBDfans (direct from taobao)
Last week I started building it with these specs in mind:
-Garistotle (gateron blue housing and spring | Aristotle stems)
-Zeal Screw In stabilizers
-Alu plate and Case
-75% pcb
After modding all the switches and installing all the stabs
I mounted some switches and tested the stabilizers, everything seemed fine until i tested the spacebar, garistotles are supposed to be clicky, but the spacebar wasnt clicking. so i tested various stuff until i noticed this
http://gph.is/2lBHnTF
The stab wire actually hits the plate on this spot:
What i tried to do already:
1. Change spring(mx clear spring) coz i thought the switch couldnt handle the weight of the spacebar
2. Change the wire coz i noticed that zeal wires are thicker than the chinese wire and gmk wire
3. FLIP the stab but yeah it doesnt work as shown below:
So aside from Modding the plate itself(i checked whether it was an issue on this specific plate alone but i have 2 of these and they are shaped the same),
Any other ideas guys?
« Last Edit: Thu, 23 February 2017, 23:40:22 by potatobot »
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: [HELP] KBD75 Stabilizer vs Plate ISSUE
« Reply #1 on: Fri, 24 February 2017, 00:07:05 »
It looks to me like you would need to file out a slit in the plate large enough for the wire to come up at that angle through the hole. If you have a cheap steel wire you can test with you might try making a bend or filing the wire flat in that area to try and get some more articulation? from it. I wouldn't risk ruining those gold wires though.
(great documentation by the way)
-Dana
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #2 on: Fri, 24 February 2017, 00:23:07 »
yeah that was the only thing i can think off, but it might ruin the finish on the plate, especially the other one coz its black. :(
contacted the seller/maker from china, i hope they understand what i mean.
Offline Tally810
« Reply #3 on: Fri, 24 February 2017, 08:13:37 »
Have you tried flashing the pcb yet? Mine came with the arrow keys backwards along with a few other people I talked to and it won't take a flash
-Alu plate and Case
-75% pcb
Sent from my SM-G928V using Tapatalk
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #4 on: Fri, 24 February 2017, 08:24:04 »
-Alu plate and Case
-75% pcb
oh, is there a fix? i havent tried flashing it yet T_T
Offline Tally810
« Reply #5 on: Fri, 24 February 2017, 08:30:59 »
-Alu plate and Case
-75% pcb
Not sure was just wondering if yours was the same way as mine and several other people I've talked to :/
