Author Topic: [IC] Mini RGBW Board  (Read 4151 times)
Offline HeroXLazer
« on: Sun, 26 February 2017, 01:29:15 »
Have you ever seen a per key RGB ortholinear keyboard? I don't think they're many of them. Have you ever wanted something smaller than a Planck, but ortholinear? Have you seen any RGBW keyboards? This keyboard is a smaller version of the Planck, it has RGBW LEDs, it can support any MX switch. It has underglow and per switch RGBW. It does use Micro-USB as those cables are more common, and they're are magnetic versions of them. Also, the name is not final by any means. :) Here are some PCB renders and some quick Sketchup pictures. Leave feedback and criticism in the comments. PCB/Sketchup Pictures: http://imgur.com/gallery/HveHm KLE file: http://www.keyboard-layout-editor.com/#/gists/cf37a9ec54801d30ce31fb3fb0c13e1e
Offline scwoopz
Re: [IC] Mini RGBW Board
« Reply #1 on: Sun, 26 February 2017, 01:41:45 »
Personally I think that on a board of that size that many 1.5u keys is a complete waste. Go full 1u. Other than that, looks good!
Sent from my ONEPLUS A3000 using Tapatalk
ortho or shmortho
Offline HeroXLazer
« Reply #2 on: Sun, 26 February 2017, 01:43:34 »
The reason I did the 1.5u key is just personal preference, and there's a space for the ATMEGA32U4 to stay nicely.
Offline aznreaper
« Reply #3 on: Sun, 26 February 2017, 02:34:42 »
Too small for me, I would be interested if it was something closer to the size of a planck
Offline pomk
« Reply #4 on: Sun, 26 February 2017, 04:05:25 »
Where have you found rear entry addressable rgbw leds?  :-X
Offline tobsn
« Reply #5 on: Sun, 26 February 2017, 05:43:25 »
they're available but they're just very expensive (20 cents a pop) - Google for reverse mount rgb SMD led
Offline pomk
« Reply #6 on: Sun, 26 February 2017, 05:58:22 »
rgbW and addressable? I have not been able to find any.
edit: just basic reverse mount RGBs go for 10-12 cents a piece (EASR3212RGBA0)
« Last Edit: Sun, 26 February 2017, 06:01:48 by pomk »
Offline tobsn
« Reply #7 on: Sun, 26 February 2017, 06:02:16 »
Offline pomk
« Reply #8 on: Sun, 26 February 2017, 06:06:29 »
Offline tobsn
« Reply #9 on: Sun, 26 February 2017, 06:08:11 »
Hmm, maybe OP can show us the way.  :)
I bet he didn't consider the availability, cost of parts, and cost of pick&place  :P
Offline pomk
« Reply #10 on: Sun, 26 February 2017, 06:31:42 »
Pick'n'place itself isn't that expensive. The cost of components, especially for the prototypes, are a lot more.
