Author Topic: Vintage MX Blacks vs. Green SKCL Alps - Which is smoother?  (Read 7690 times)
Offline IBMPCDOS5
  • I have no idea what to put here.
« on: Sun, 26 February 2017, 21:39:36 »
In today's MK industry, the leading linear switch are the infamous Cherry MX Blacks. Compared to MOST linear switches, Blacks feel rough, scratchy and overall unpleasant to type on. Yet back in the 80's, "Vintage" Blacks were considerably much smoother. Some report that it feels almost lubed. Alps also made fantastic linear switches, notably the SKCL Green switches in particular. So how comparable are they? Both seem to be smooth and absolutely gorgeous to the ears.
Sent from my SM-S120VL using Tapatalk
Offline davkol
  •  Post Editing Timeout
Re: Vintage MX Blacks vs. Green SKCL Alps - Which is smoother?
« Reply #1 on: Mon, 27 February 2017, 04:29:13 »
Alps switches age terribly and suffer from dust exposure. SKCL Green, that I've used, felt awful.
That said, old MX Black may feel suboptimal too in some cases (I have poorly stored Wyse and other non-Cherry boards in mind specifically).
That said, I consider harvesting from the best OG Cherry boards a heresy, although I actually don't quite feel the same about most keyboards with Alps switches.
Offline pr0ximity
« Reply #2 on: Mon, 27 February 2017, 05:13:47 »
They're a bit different. I'd say when clean and properly lubed they are equivalently awesome, however SKCL have a very slight tactility due to their contact leaf design. So Blacks are the more purely smooth, uninterrupted linears.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #3 on: Mon, 27 February 2017, 05:44:03 »
I've had relatively bad luck with SKCL green so far, neither of mine are in good condition. However, linearised black Alps are at least as smooth as vintage blacks, if not smoother, I'd say. As mentioned, they also have an ever so slight tactility, which IMO makes for a less boring keyfeel. Also, I consider the weighting to be much better as MX blacks are too heavy for me. I can't speak for myself, but apparently SKCL green in NOS condition are ridiculously good - which I can imagine, because even my crappy ones were good enough that I typed my entire 300-page PhD thesis on them.
Offline IBMPCDOS5
« Reply #4 on: Mon, 27 February 2017, 06:57:30 »
I am well-aware of that miniscule tactility that every Alps switch has with a switchplate. So the smoothness is quite comparable to Linear Black Alps/Green Alps but the keyfeel is completely different due to keyfeel and that tactility?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #5 on: Mon, 27 February 2017, 11:17:19 »
Vintage blacks are smooth, but vintage green alps are smoother if you get them clean
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline menuhin
« Reply #6 on: Mon, 27 February 2017, 17:58:20 »
I have a NOS keyboard with SKCL greens, but I don't have any Vintage MX blacks with me.
If you allow me to borrow the opinions of some of the MX switches experts here (in a few threads said vintage blacks, nixies, and Gateron blacks are very similar except for the wobbles) and let me compare Gateron blacks on a few months old modern keyboard with NOS SKCL greens, I would say both are very smooth, obviously smoother than modern MX blacks, but Gateron blacks are even tiny bit smoother giving my fingers a bit of a buttery smooth sensation.
The comparison was not totally fair: SKCL greens had PBT caps and Gateron blacks had POM caps. The 'slippery' characteristics of POM caps might have intensified the sensation of smoothness during key presses.
IBM M13 black
NeXT non-ADB keyboard (AAE)
HHKB Pro 2 HasuBT
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #7 on: Mon, 27 February 2017, 18:12:07 »
Cherry Silvers
Offline Potatomonkey
  • Tsangan best row
« Reply #8 on: Mon, 27 February 2017, 21:59:18 »
Offline IBMPCDOS5
« Reply #9 on: Mon, 27 February 2017, 22:16:47 »
Offline mike52787
  • Alps Aficionado
« Reply #10 on: Tue, 28 February 2017, 19:24:43 »
weighing the pros and cons of each, and both are great switches, I would rather use the V blacks instead of the SKCL greens. I just like them better. both are good linears. I just think that tuned vintage blacks are just that much better.
Offline klennkellon
  • I like bottoming out
« Reply #11 on: Wed, 01 March 2017, 02:06:52 »
Vintage Alps are great and all but at the end of the day just getting some Gaterons is a better idea. They're smooth and cheap and available in a variety of weights. Of course they don't sound as good as Alps but they're just linear switches at the end of the day.
However tactile/clicky MX based switches are nothing compared to tactile or clicky Alps!
Offline wodan
« Reply #12 on: Wed, 01 March 2017, 02:35:49 »
That is total rubbish. How did you come up with this claim?
Hardly ANY modern keyboard comes with MX Blacks. They used to be the leading linear switch in the late 80s and 90s.
Complicated gree Alps have the same issue all Alps have - people love the IDEA of this switch and how it feels brand new. But the comments in this thread clearly show you what a piece of crap even complicated green Alps are ... they will eventually start to feel like ****. Even if you get them NOS/NIB ... using them means "using them up" unless you are willing to desolder the whole board (such a pain with Alps switches - WHO BENDS ALL THESE LEGS !?!) and do a full cleaning job on them to restore them back to near-NIB.
On the other hand ... you can see that MX Black switches from the 80s are in expecially high demand today and few people ask about the condition of them. They hardly suffer from use - and some MX switch types are even more desirable after being heavily used!
So what are you really asking? What's better: NOS 80s MX Blacks or NOS Complicated Green Alps?
Stop troubling your mind with all these hypothetical questions, MX switches are the best PRACTICAL linear switches. There's a reason Cherry has been making them _NEARLY_ unchanged in design for more than 30 years and the original 80s design is currently dominating the MK market. Not a single Alps switch has been made for even a fraction of that time ...
Offline happylacquer
  • BS Apologist
    • BHOBuds
« Reply #13 on: Wed, 01 March 2017, 02:56:58 »
Topre for sure.
Offline menuhin
« Reply #14 on: Wed, 01 March 2017, 06:22:30 »
Topre for sure.
It's kind of a trolling post here ...  :))
But Topre being as smooth if not smoother than Vintage Black can be true according to the readings from Haata's key force gauge.
Notice the more obvious tiny fluctuations in the curves of modern MX black.
After all, Topre's rubber dome is made of rubber. How can rubber be not smooth?
P.s. Here are links to some other measured force curves:
Alps SKCL Yellows (usually people prefer Greens because they think Greens are lighter and better)
Gateron Red
https://plot.ly/~haata/150/gateron-red/
Cherry MX Red
https://plot.ly/~haata/88/cherry-mx-red/
Cherry RGB MX Red
https://plot.ly/~haata/268/cherry-mx-red-rgb/
« Last Edit: Wed, 01 March 2017, 06:45:44 by menuhin »
IBM M13 black
HHKB Pro 2 HasuBT
Offline IBMPCDOS5
« Reply #15 on: Wed, 01 March 2017, 06:42:52 »
Topre for sure.
Oh, I've seen scratchy rubber domes, but I'm not sure if it's because of the actual rubber or the slider well it's in. They still somehow managed xD
Offline chyros
  • a.k.a. Thomas
« Reply #16 on: Wed, 01 March 2017, 07:14:40 »
Oh  dear, you don't want to know what kind of rubber monstrosities are out there xD .
In fact, rubber has inherent great friction. It's used as a friction-adding material in many applications, even.
Offline IBMPCDOS5
« Reply #17 on: Wed, 01 March 2017, 07:19:14 »
Still, those force curves made me want Topre even more than ever, seeing how smooth they are new.
Offline menuhin
« Reply #18 on: Wed, 01 March 2017, 08:26:38 »
Oh right, some rubber doms even have enhanced friction and people like them a lot.  :p
... but wait..!
I'm not talking about rubbing onto the surface of some rubber material. I am talking about the 'smoothness' of reaction of rubber when it is under stress / force due to rubber's property even when they are molded in dome shapes. And we are not directly comparing rubber in dome shapes to some solid pieces of metal, but to certain kind of metal cast and formed into spring structures, which give them extra flexibility and different properties when the whole structural unit is stress.
i.e. how smooth the movement of the structure in reaction to stress in the forms of: compression, tension, shear, and torsion.
IBM M13 black
HHKB Pro 2 HasuBT
Offline chyros
  • a.k.a. Thomas
« Reply #19 on: Wed, 01 March 2017, 08:43:42 »
... but wait..!
That's fair enough, but there's no way you're going to convince me that rubber is smoother when pressed than a metal spring :p .
Offline menuhin
« Reply #20 on: Wed, 01 March 2017, 10:50:05 »
Physical aspects of the material and structure of a key switch are mostly about a deformation design - i.e. about a structure (made of certain material of choice) that will give during a key press and will return to its original shape upon release. Of course, there are details, e.g. the force required to further collapse this structure (force curve), and the time it takes to bounce back, etc.
Rubber is actually quite suitable for this task. The ingenuity here is also that by molding it into certain forms, the structure can provide a more linear or a more tactile force curve (perhaps metal can too but I can't see such a metal structure exists). Certain elastic rubber or polymer compounds can be stronger than if not just comparable to steel, and these materials can maintain their shapes even better.
I think our disinterest (or dislike, or even hatred... xD) in rubber is due to its apparent short lifespan. I also witnessed how quickly rubber bands can become unusable. I hope the rubber dome sheets in Topre or in some other rubber dome keyboards that I like can last longer, after all there are now rubber materials that are resistant to UV, oxidatoin / ozone, and temperature.
I tried to find out how long can rubber (or specifically in here those rubber dome sheets) last before they need to be replaced. And what conditions lead to their degradation - physical movement (usage)? exposure to certain chemicals? exposure to other things such as light (UV) or extreme temperature? So far, I found no answer about how long they can last - except for information of changing tires and changing rubber for table tennis paddles - where both usage are friction related. These users said - probably they need to replace there rubber components once per year..!
Okay HHKB users...  :eek:
Physical properties of rubber
Deformation (related measurements)
Usage of rubber for shock isolation
[ur=http://www.sts-schwingungstechnik.de/en/gummi-als-baustoff/l]Usage of rubber in construction[/url]
« Last Edit: Wed, 01 March 2017, 11:49:12 by menuhin »
IBM M13 black
HHKB Pro 2 HasuBT
