Author Topic: Cherry G80-3000 vs Cherry G84-4100 (ML4100)  (Read 5451 times)
Offline sec908
« on: Sat, 06 February 2010, 08:24:21 »
Hi!, I've a G84-4100 but this has the keys very smalls. I'm thinking change my actual keyboard to the G80-3000 but I think that this keyboard is very big (G80-3000 47cmx19cm) vs (g84-4100 28cmx13cm).
I find a keyboard good for coding (i'm developer) not gaming and my actual g84-4100 (ML4100) not is confortable but when i type on it, the key touch and sound (click click) is nice but keys as "enter, backspace, space alt gr, alt, windows, control, insert, del, ´ , [], {}" the keys are close together.
Do you think i should change my actual keyboard to the G80-3000? I've little space in my desktop.
Offline lal
« Reply #1 on: Sat, 06 February 2010, 09:31:43 »
I think you should change you keyboard to a Filco Tenkeyless with the switch you like.  Since saving space is one of your top priorities, I would *not* recommend a G80-3000.  The G84s you already have are about as small as mechanical boards can get.  Anything else will be bigger.  The G80-3000 is full-size, as in "really huge".
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline platon
« Reply #2 on: Sat, 06 February 2010, 09:45:33 »
Quote from: lal;156733
Very well said.
Filco Majestouch brown no nkro, Filco tenkeyless white lettered with browns, IBM Model M 1392934 Space Saving \'91 x 2, Cherry G80-3000 LSCEU-2, Chicony KB-5181, SGI Granite 9500900, IBM Model M 52G9658 \'94, HHKB Lite 2 for Mac, SGI RT6856T (rubber dome), Logitech Illuminated Keyboard, CH DT225 trackball, SGI 063-0009-001 mouse
Offline sec908
« Reply #3 on: Sat, 06 February 2010, 09:53:53 »
Thx!! I think about the Filco, but I'm spanish (i need the key "ñ") and i'm thinking... but thx for all the help!! :)
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #4 on: Sat, 06 February 2010, 10:30:30 »
Is that Linux you're using there?
Offline sec908
« Reply #5 on: Sat, 06 February 2010, 10:36:37 »
Quote from: microsoft windows;156742
I use Linux (gentoo) and Mac OS X (Snow Leopard) with synergy application.
Offline EnergizerFellow
« Reply #6 on: Sat, 06 February 2010, 13:43:56 »
Quote from: sec908;156737
On that note, Filco needs to make a tenkeyless board with US International ANSI layout and numpad overlay.  Filco's JIS bottom row has a usefully sized spacebar for Western languages, plus enough keys for Fn and Alt Gr.  May as well add some media keys as Fn alternates to the F-key row too.  Any bets if such a beast will ever be made?
« Last Edit: Sat, 06 February 2010, 13:45:57 by EnergizerFellow »
