Author Topic: MX HHKB plates?  (Read 3782 times)
Offline CapnHighlands
MX HHKB plates?
« on: Mon, 27 February 2017, 15:28:04 »
I was wondering if anyone knows of MX HHKB plates that I can purchase for a custom build. I know LeandreN has some over at Mekanisk, but I was wondering if there are any in stock/with a 6.25u spacebar.
Re: MX HHKB plates?
« Reply #1 on: Mon, 27 February 2017, 16:26:59 »
buy a universal plate and cut it
seems like an easier solution, no?
Re: MX HHKB plates?
« Reply #2 on: Tue, 28 February 2017, 17:44:05 »
Well I just realized the reason the LeandreN plate comes with a 7u spacebar is because of the PCB spacing. I feel silly now.
Offline TalkingTree
    • My projects
Re: MX HHKB plates?
« Reply #3 on: Wed, 01 March 2017, 03:06:17 »
Spacing? I though it was more like symmetry.
If anything else than 7u, you'd probably consider a 6u spacebar.
Re: MX HHKB plates?
« Reply #4 on: Wed, 01 March 2017, 16:51:48 »
Well I meant more there isn't a PCB that can support the actual HHKB layout. Unless I'm wrong and the FaceW can. This is the layout in question:
http://www.keyboard-layout-editor.com/#/gists/ca2429e3996c9a1a4cefead61b6b21eb
Is there any way of figuring out if a FaceW will support this?
Offline TalkingTree
    • My projects
Re: MX HHKB plates?
« Reply #5 on: Wed, 01 March 2017, 17:06:31 »
I gave my FaceW to a friend so I can't tell.
Although I can vouch for the Winkeyless.kr B.face X2 to support it.
Re: MX HHKB plates?
« Reply #6 on: Wed, 01 March 2017, 17:43:19 »
Oh. Wow. Thanks for pointing this out. Do you know how I would get a plate for this?
EDIT: Also, where would I get a spacebar stab?
« Last Edit: Wed, 01 March 2017, 17:48:19 by CapnHighlands »
Offline ArchDill
Re: MX HHKB plates?
« Reply #7 on: Wed, 01 March 2017, 18:05:50 »
I use an MX HHKB and a HHKB Pro 2. I prefer the 7u spacebar on my MX HHKB. The real HHKB layout is off centered. It was hard for me to overcome at first haha
Offline Latin00032
Re: MX HHKB plates?
« Reply #8 on: Wed, 01 March 2017, 22:12:50 »
Most pcbs or plates that support 6u or 6.25u are off center.
The 7u is a centered spacebar.
Offline Latin00032
Re: MX HHKB plates?
« Reply #9 on: Wed, 01 March 2017, 22:16:21 »
Does it need to look like this?
