Author Topic: SOLVED: How do I correctly re-insert a spring on the model M?  (Read 70880 times)
Offline Superfluous Parentheses
« on: Sat, 06 February 2010, 13:10:58 »
Hi. I've just managed to have a spring jump out of my model M when experimenting with an alternative layout.
I can manage to put it sort-of back in, but it's not stuck as well as the other springs appear to be (and I'm not going to yank on the other ones now!)
Anyway, the key is now non-clicky, non-feedback and unreliable.
Is there a good way to get the spring back right without having to open up the whole board? As far as I can tell there's an upturned V "groove" that it should stick onto, but I can't really see it that well.
Cheers,
SP.
« Last Edit: Sat, 06 February 2010, 14:49:26 by Superfluous Parentheses »
Current collection: HHKB Pro 2 black on black, HHKB Pro 2 white/grey blank, [strike]Dell AT101W[/strike] (sold to SirClickAlot), 1992 Model M, Key Tronic Ergoforce KT 2001, BTC 5100 C. Dead boards: MS Natural Elite, MS Natural 4000.
« Reply #1 on: Sat, 06 February 2010, 13:27:34 »
Quote from: ripster;156776
Try looking in the mods section of the forum since there are two spring removal/installation guides in this very section.  Like where you posted (I can be obnoxious since your post count is over 10).
Oh OK, here.
I don't care that you're obnoxious. I'm just glad that you responded so quickly :)
Thanks, I'll have a look.
« Reply #2 on: Sat, 06 February 2010, 13:47:25 »
Update: ripster's method worked perfectly!
Thanks again, ripster!
« Reply #3 on: Sat, 06 February 2010, 14:49:07 »
Oh, sorry about that. I figured the mods section would be the most likely place where people would know about replacing springs.
