Author Topic: Smooth ABS Doubleshot DSA keycap sets?  (Read 6969 times)
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« on: Tue, 28 February 2017, 22:23:31 »
Is this a thing? I know that SP can make DSA smooth as SA, but are there any sets which exist in this smoothness?
Deep Space looks to be like this, but is it really?
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline hking0036
Re: Smooth ABS Doubleshot DSA keycap sets?
« Reply #1 on: Wed, 08 March 2017, 06:12:24 »
Evidently, Deep Space DSA is Doubleshot: http://pimpmykeyboard.com/dsa-deep-space-keycap-set/
I would think that DSA is too short for that but evidently not. Still, I think that's not going to be super common considering people's wants leaning toward PBT these days.
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
Offline wodan
« Reply #2 on: Wed, 08 March 2017, 06:19:33 »
From what I have heard, the texture of a keycap is part of the mold and not part of a finishing process.
So changing the texture of a keycap requires creating all new molds - probably the expensive "outer" molds in the doubleshot process.
Offline 00zeRO
« Reply #3 on: Wed, 08 March 2017, 07:10:37 »
Not true. SP defaults to texture unless a person asks for otherwise. I was just wonder which sets are not textured
Offline cutterline
« Reply #4 on: Wed, 08 March 2017, 08:29:52 »
Correct, because it is cheaper and simpler that way.
Surface treatment (smoothing or texturing) adds another process(es), tool(s), and failure rate making the cost higher. Hence, making it as "why bother if you can make it simpler?"
Offline 00zeRO
« Reply #5 on: Wed, 08 March 2017, 08:38:22 »
Because its squattier and can feel like SA
Offline Tactile
« Reply #6 on: Wed, 08 March 2017, 08:44:44 »
No color choice but Filco makes a nice set. They are very smooth and have a bit of a 1990's look. They are not black/white but instead brown/ivory.
REΛLFORCE
Offline 00zeRO
« Reply #7 on: Wed, 08 March 2017, 08:48:40 »
Yisss...I have a set. I love it.
The conversation at hand is about DSA profile and smooth sets in it. I can only think of Deep Space, but I don't really like the colorways in it. So, I posed the question as to whether there may be others out there I don't know about.
Offline zslane
« Reply #8 on: Wed, 08 March 2017, 12:37:11 »
Not that I'm aware of.
Deep Space is double-shot but the texture is matte, just like Dolch, Eve, etc.
