Author Topic: Programming JigOn in OSX w/ Windows guest VM  (Read 2109 times)
Offline doom2
« on: Wed, 01 March 2017, 15:11:21 »
Trying to program my TX-CP using a Windows VM (macOS 10.12.3 host, Win 8.1 guest) and the JigOn software (version 151116). Plug the keyboard in, start up JigOn, go to Keyboard --> Connect. JigOn gives me a "connected" popup, but when I press a key on the board, it doesn't register in JigOn. When I map in JigOn, it gives me an affirmative message that it wrote to the keyboard, but testing it shows it didn't work.
Thoughts? Something I have to change in Virtualbox to make the keyboard recognized correctly?
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: Programming JigOn in OSX w/ Windows guest VM
« Reply #1 on: Thu, 02 March 2017, 01:26:11 »
Is it just that it doesnt work through VM? It works normally in OSX?
-Dana
Offline doom2
« Reply #2 on: Thu, 02 March 2017, 06:11:54 »
To program the keyboard, you need the JigOn software, which is Windows-only.
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #3 on: Mon, 06 March 2017, 21:07:56 »
If you can enable pass-through of the USB device to the VM you may have success.
Using emulated devices won't work.
