Author Topic: RGB LED PCB Help  (Read 2607 times)
Offline HeroXLazer
RGB LED PCB Help
« on: Wed, 01 March 2017, 20:32:15 »
So, I want to use a LED driver with RGB LEDs, and I want to use SMD RGB LEDs that only have four pins. They have a R pin, a G pin, a B pin, and a VDD/VCC pin. The driver I'm going to use uses Charlieplexing, and I'm confused on how to Charlieplex with single pins. I figured out to do it if you have two pins on each LED, but not with one pin. Could someone please explain how to wire it to the driver?
MCU: http://www.atmel.com/Images/Atmel-7766-...ummary.pdf LED Driver: http://www.issi.com/WW/pdf/31FL3731C.pdf RGB in LED Driver Example: http://www.issi.com/WW/pdf/31FL3732.pdf RGB LEDs: http://www.lumex.com/sml-lx0404siupgusb
« Last Edit: Wed, 01 March 2017, 21:09:15 by HeroXLazer »
Offline poang
Re: RGB LED PCB Help
« Reply #1 on: Wed, 08 March 2017, 22:24:59 »
why don't you use ws2812b?
Offline pomk
« Reply #2 on: Thu, 09 March 2017, 01:20:10 »
My guess would be cost and more importantly the lack of reverse mount option or some other size constraint.
Offline HeroXLazer
« Reply #3 on: Thu, 09 March 2017, 08:23:59 »
I was going to, but then I thought about assembly.
Offline cribbit
« Reply #4 on: Thu, 09 March 2017, 12:19:28 »
Charlieplexing is really, really hard to describe.
A ws2812b is just as hard to stick on as a normal SMD LED.
You're going to have an easier time just using a standard matrix.
I typed this post on my Slanck. I also developed a stronger, cleaner, easier handwiring method.
Offline HeroXLazer
« Reply #5 on: Thu, 09 March 2017, 16:36:21 »
Yeah, because of that I just decided to use the ISFL3733, it's not charlieplexed. The hardest part is going to be firmware.
