Author Topic: Lubrication  (Read 7034 times)
Offline mniels
Lubrication
« on: Thu, 02 March 2017, 18:49:00 »
So, I have been using the Krytox mix sold by Techkeys, but am looking to be able to purchase more than a 2ml vial (especially at $9.00 a pop.)
What do you guys use?  Your own blend?  Something pre-made like the Techkeys product?
Offline need
Re: Lubrication
« Reply #1 on: Thu, 02 March 2017, 19:17:37 »
i use silicon grease
Offline Wingklip
  • I am the one the one the one the one the one
Re: Lubrication
« Reply #2 on: Thu, 02 March 2017, 19:37:10 »
WD 40 maybe.
Probably Vaseline would be decent, though you should think it out with some oil or something
« Last Edit: Sun, 05 March 2017, 22:12:25 by Wingklip »
If you 1v1 me in a cage fight I will use an AK-74 for ranged and an IBM model F 122 for melee
Re: Lubrication
« Reply #3 on: Thu, 02 March 2017, 20:18:24 »
WD 40 maybe.
You can't be serious.
We are talking lubing keyboard switches right?
Offline mniels
Re: Lubrication
« Reply #4 on: Thu, 02 March 2017, 20:19:09 »
Yeah switches. Was a little concerned about that post as well, lol
Offline TalkingTree
    • My projects
Re: Lubrication
« Reply #5 on: Fri, 03 March 2017, 03:56:02 »
Vaseline is a petroleum lubricant and it shouldn't be used on styrene. I guess switches housing are made of polyoxymethylene but, nonetheless, you don't want vaseline to dissolve your ABS keycaps.
Silicone grease would work unless you use too much which would make your switches gummy.
Re: Lubrication
« Reply #6 on: Fri, 03 March 2017, 17:40:43 »
silicone grease is what most switches are designed for
it's basically the generic brand of krytox, but krytox seems to be a fan favorite
Offline justinmtype
Re: Lubrication
« Reply #7 on: Fri, 03 March 2017, 17:43:07 »
Silicon grease is different than teflon grease.
Offline Wingklip
Re: Lubrication
« Reply #8 on: Fri, 03 March 2017, 17:51:49 »
Omg what have I done D: nearly forgot it was a solvent too
Dang hydrocarbons.
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: Lubrication
« Reply #9 on: Sat, 04 March 2017, 07:23:40 »
Just make your own Krytox mix. You can buy GLP 205 and 103 on Zoro in reasonable amounts, 0.5oz or so. It'll cost $50 and last ages.
Offline justinmtype
Offline mniels
Re: Lubrication
« Reply #11 on: Sat, 04 March 2017, 19:27:59 »
What ratio are you using?
Offline pr0ximity
Re: Lubrication
« Reply #12 on: Sun, 05 March 2017, 05:20:20 »
GPL104, I didn't like the TechKeys mix much, felt too thin and seperates easily.
Offline zpcomstock17
Re: Lubrication
« Reply #13 on: Sun, 05 March 2017, 21:04:26 »
GPL 205, the stuff's great.
Even broke the seal with my canine tooth and tasted some of it, tastes great too.
Offline cynviloq
Re: Lubrication
« Reply #14 on: Mon, 06 March 2017, 20:54:02 »
I sell a bundle of VPF 1514 (viscosity sits between GPL 103/104) with GPL 204 here: https://mehkee.com/products/krytox-lube-oil-and-grease?variant=37699586639.
I don't pre-mix because everyone has their own preference so they come in two separate vials with applicators (5mL total for $10.99).
If you buy in bulk, you'll have enough for a lifetime, but it's harder to find GPL oils in less than 0.5kg bottles.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
Re: Lubrication
« Reply #15 on: Mon, 06 March 2017, 21:18:36 »
Basically what I do as well... 205 and 100 mixed till about a yogurt consistency and then brushed on the switch stem contacts. I just do a light dab of 100 oil on the ends of the springs.
-Dana
Offline lakiozoon
« Last Edit: Sat, 01 April 2017, 07:29:55 by lakiozoon »
Offline mniels
Re: Lubrication
« Reply #17 on: Sat, 01 April 2017, 08:07:26 »
I actually ended up with a mix of 205/103 at a ratio of about 60/40.  .5 ounce of 205 at $29 from Amazon and .5 of 103 from Zoro at $19.  Five bucks for a  glass 2 oz jar and you end up with a lifetime supply for $55.
Considering the amount of switch lubing I do, it is pretty much a no-brainer for me.  If you are only doing one or two boards, then I definitely see the appeal of getting the smaller amount and being done with it, but bulk made more sense to me personally.
Offline northpark
Re: Lubrication
« Reply #18 on: Mon, 03 April 2017, 08:09:01 »
I didn't realize this was a thing... so much research to do!
Offline dubious
  • 쏘쿨
Re: Lubrication
« Reply #19 on: Mon, 03 April 2017, 13:14:48 »
I did some research on VPF 1514, and I am not sure it's an appropriate lubricant for mechanical switches. I couldn't find a lot of data on this, but one note in their brochure concerned me:
"There is some reactivity of the additive with copper, but it is less with brass."
I know you shouldn't be lubricating your copper leafs anyway, but the potential for corrosion seems risky. I also don't see them mention anywhere that it is a dielectric lubricant. :/
Offline cynviloq
Re: Lubrication
« Reply #20 on: Mon, 03 April 2017, 13:20:19 »
Hi - very much appreciate you looking further into it, but you are referring to the VPF versions that contain "antirust protection" properties, which is a solube additive to prevent rust.
Normal Krytox VPF does not contain that additive, is nonreactive, and has high dielectric properties.
The lubricant on my site is normal Krytox VPF without the soluble additive!
Offline dubious
  • 쏘쿨
Re: Lubrication
« Reply #21 on: Mon, 03 April 2017, 13:31:01 »
ahh you are correct, I was looking at VPF XP.
I may be placing an order with you soon.
Offline cynviloq
Re: Lubrication
« Reply #22 on: Mon, 03 April 2017, 17:53:55 »
No worries, DuPont doesn't make it easy to find all the information about products in one setting! Everything is spread across various PDFs and it's hard to differentiate older versus updated information.
