Author Topic: Kiibohd  (Read 2126 times)
Offline TouchTypist
Kiibohd
« on: Sat, 04 March 2017, 23:47:48 »
Does anyone have experience with this firmware or know more about it? I have a teensy lc that I had long ago planned to use for a keyboard. I don't really think I'm up to the task of writing my own code for the project, and kiibohd seems promising. My particular board isn't listed but I had hoped it might still work? If not I can just go ahead and buy a 2.0
Offline hking0036
Re: Kiibohd
« Reply #1 on: Mon, 06 March 2017, 09:27:53 »
Kiibohd is HaaTa's baby so I'm sure it's fairly solid. He'll probably answer any questions you have if you PM him. AFAIK QMK/TMK are for specific microcontrollers but I'm way out of my depth here so I can't really speak on that.
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
Offline joey
Re: Kiibohd
« Reply #2 on: Mon, 06 March 2017, 09:31:29 »
QMK/TMK has been moving towards working on ARM too now.
You'll probably have to write some code for whatever controller you use. But I don't think Kiibohd supports Teensy LC.
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
Re: Kiibohd
« Reply #3 on: Mon, 06 March 2017, 10:34:39 »
Yeah, Teensy LC doesn't really have enough RAM to work with Kiibohd. It might be possible to make work, but it's a lot of effort for an experienced embedded C programmer.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline TouchTypist
Re: Kiibohd
« Reply #4 on: Mon, 06 March 2017, 13:48:37 »
Which I am not, so perhaps I best steer clear of the attempt :) Teensy 2.0 it is, for this keyboard anyway.
