Author Topic: Connecter Choices?  (Read 1779 times)
Offline HeroXLazer
Connecter Choices?
« on: Mon, 06 March 2017, 18:25:50 »
For my RGB keyboard, I need a 12 pin connector to connect two sides. Do you guys know of any connectors that would be the best at this? I was wondering if there is anything smaller than USB C that would work for me?
Offline TalkingTree
    • My projects
Re: Connecter Choices?
« Reply #1 on: Tue, 07 March 2017, 04:00:47 »
Smaller than USB type-C? I highly doubt it. Bigger but easier to set up? Molex.
Offline hanya
« Reply #2 on: Tue, 07 March 2017, 08:19:40 »
Mini displayport connector is 12 pins connector. Micro HDMI connector has 19 pins.
You would have problems caused by noise if you want to communicate between sides in long distance.
PFU HHKB JP, Sanwa MA-TB38 trackball
