Author Topic: [GB] VE.A Wooden Wrist Wrests - Shipping Soon  (Read 82288 times)
Offline alienman82
« on: Tue, 07 March 2017, 00:26:14 »
removed.
« Last Edit: Thu, 01 March 2018, 13:04:44 by alienman82 »
Offline Oblotzky
  • Backspace is for people that make mistakes.
Re: [GB] VE.A Wooden Wrist Wrests
« Reply #1 on: Tue, 07 March 2017, 11:03:16 »
Are the price breakpoints per wood type or overall number of orders?
Offline bendrexl
« Reply #2 on: Tue, 07 March 2017, 11:35:35 »
Both - the cost of every order goes down as the total order count increases - that's the left-to-right columns.
Each wood type will drop to its own "bulk" price once 4 sets using that as the primary are ordered - that's the top vs bottom chart.
It's a little complicated, but we want to be as transparent as possible.
EDIT: Here's a chart showing the current pricing. Note that quantities are manually updated, so may not include very recent orders: https://goo.gl/eAY71B
EDIT 2: The chart is now auto-updated every few min.
« Last Edit: Tue, 07 March 2017, 18:44:08 by bendrexl »
Offline litster
  • rare caps?! THAT'S A SMILIN
« Reply #3 on: Tue, 07 March 2017, 12:20:35 »
Submitted.  Would be good to get a count of each option to see if we could consolidate some orders to make better pricing.  It is great there are so many options, but on the other hand, there are so many options it may dilute the orders and harder to get to bulk pricing.  Any inquiries from our friends in South Korea?  I hope they buy a lot :D
Offline Data
« Reply #4 on: Tue, 07 March 2017, 13:16:47 »
Dat Wenge...  :eek:
But dat price...  :-[
I may have to go Walnut.  Need to wait and see where order numbers are falling.
Offline zacheadams
« Reply #5 on: Tue, 07 March 2017, 17:32:51 »
Dat Wenge...  :eek:
Pls son, cmon and go wenge!!!
Two questions:
1. Will there be updates on how many orders are made for each until the groupbuy ends?  (A spreadsheet of this with total counts would be awesome.)
2. Per #1, would we be able to switch our orders at the end if there's something that meets a pretty good #, so we can help the GB overall stick to a minimum # of variants for our supplier (and also get better discounts/hit higher MOQ breakpoints)?
Cheers and thanks as always!
Offline alienman82
« Reply #6 on: Tue, 07 March 2017, 18:10:29 »
removed.
« Last Edit: Thu, 01 March 2018, 13:04:31 by alienman82 »
Offline roostrc0gburn
  • its just plastic
« Reply #7 on: Tue, 07 March 2017, 18:20:22 »
may consider changing the form... kinda annoying to have to enter a "0" for everything i dont want. might lead to errant submissions.
anyway, i'm in for wenge/zebrawood. hope some more ppl join me  ;D
Offline Vloshko
« Reply #8 on: Tue, 07 March 2017, 18:55:05 »
What type of finish are you going to do on the Open Grain & Open Pore wood?
Wenge is a pain in the butt to work with, that stuff is literally toxic. Getting a smooth finish with Wenge and Zebra wood is quite a difficult task since the Pores tend to be large and are randomly spread out. Are you going to use clear filler?
Personally, I love high gloss mirror like finish, I use the following steps for most of my project finishes:
Apply appropriate Filler (normally I work a lot with Open Grain wood like Walnut, so I tend to stick with water based filler)
scrape off excess after dry
use burlap to remove rest of excess until all filler is removed
220 grit light sanding
apply sealer coat of lacquer
scuff sanding with 320 grit
8 coats of lacquer then let dry for 8-10 days
Level finish wet sand using dish soap and water and 400 grit
1500 grit
wipe down
1800 grit
wipe down
2400 grit
wipe down
3200 grit
wipe down
3600 grit
wipe down
6000 grit
wipe down
8000 grit
wipe down
12000 grit
wipe down
Finish with 16000 grit
Final wipe down
Pumice Stone mixed with dish soap and water to form a paste... rub it in
Rottenstone powder made into paste with our trusty dish soap and water. Then a whole lot of hard rubbing.
Result: Glass Wood
Keycap Compendium
Discord: Vloshko#1327
Key Cap Wishlist
2019: Configure Optimal Audio Settings
HHKB Pro 2, Model M, Unicorn X Legend, ESPECTRO 96, SaiB CP, E8-V1.
Offline bendrexl
« Reply #9 on: Tue, 07 March 2017, 19:44:47 »
(snipped)
Result: Glass Wood
That treatment would put even glass to shame!  :eek:
Wood finishing is a bit of a cult, so without starting any religious debates I'll just say that we're keeping it simple, practical, and natural looking - all woods will be completely sealed, durable and highly resistant to sweat/oils from skin. The final texture will be smudge-hiding satin with the grain texture sealed but not completely filled, we're not hiding the personality of these woods. Zebrawood especially is known for displaying huge open pores at various points within the grain, part of the attraction for most folks is the unique nature of these woods.
If you would like to finish it yourself, we can make arrangements to apply whatever sealer you prefer and leave the rest up to you? :)
Offline clappingcactus
« Reply #10 on: Wed, 08 March 2017, 01:00:47 »
A little amused that the most expensive wrist-rest is the one that's being bought the most. Also a little amused that it was the end-game of all my suggestions from the previous thread put together, even though no one suggested they agreed with me. :P
Offline wodan
« Reply #11 on: Wed, 08 March 2017, 01:57:56 »
What a nice way to round up a great keyboard :)
Thanks for putting this together!
Offline Data
« Reply #12 on: Wed, 08 March 2017, 08:35:36 »
1500 grit
wipe down
1800 grit
wipe down
2400 grit
wipe down
3200 grit
wipe down
3600 grit
wipe down
6000 grit
wipe down
8000 grit
wipe down
12000 grit
wipe down
Final wipe down
Result: Glass Wood
That's a ridiculous amount of finishing work but I'm sure your projects look amazing.  You lost me at
And I honestly don't expect that level of quality for this GB, even at these prices.
Offline bendrexl
« Reply #13 on: Thu, 09 March 2017, 18:02:01 »
So true! I was also surprised - I guess you had the vision for it :D
Offline zacheadams
« Reply #14 on: Thu, 09 March 2017, 18:53:53 »
Your vision inspired us.
Will we hit bulk pricing with zebrawood or wenge since 5 zebrawood/wenge and 5 wenge/zebrawood were picked so far?
« Last Edit: Thu, 09 March 2017, 18:55:41 by mer6 »
Offline megaforce
« Reply #15 on: Thu, 09 March 2017, 20:41:38 »
Get in on more oak and black walnut my dudes!
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
  • its just plastic
« Reply #16 on: Fri, 10 March 2017, 01:13:24 »
is payment due on the 24?
Offline alienman82
« Reply #17 on: Fri, 10 March 2017, 08:25:23 »
removed.
« Last Edit: Thu, 01 March 2018, 13:03:54 by alienman82 »
Offline bendrexl
« Reply #18 on: Sat, 11 March 2017, 00:43:09 »
Already hit at 4 each, so the GB status chart is currently showing the $20-25 per unit discount for wenge/zebra (that's what I get if I order a full board vs "retail" custom cut, I'm just passing that on). Oak is a smaller discount dollar-wise ~$5-6 discount, and walnut would be ~$10-12 if I remember right. I don't have the numbers right in front of me so don't quote this post, but they're all there in the order form.
EDIT: I should've added that price for *all* styles start dropping incrementally once we get over 20 orders, the chart showing that drop schedule is linked in the order form.
« Last Edit: Sat, 11 March 2017, 00:46:13 by bendrexl »
Offline zacheadams
« Reply #19 on: Sat, 11 March 2017, 07:14:36 »
Awesome, cheers.
C'mon y'all we're so close - one more order to 20!
Offline alienman82
« Reply #20 on: Sat, 11 March 2017, 19:46:24 »
removed.
« Last Edit: Thu, 01 March 2018, 13:03:47 by alienman82 »
Offline KetchyKech
« Reply #21 on: Tue, 14 March 2017, 11:44:15 »
Thinkin of placing an order, but i wants da zebrawood- 1 quantity = 1 set (id get left & right wristrests?)
Offline bendrexl
« Reply #22 on: Tue, 14 March 2017, 12:25:57 »
Yes, ordering quantity 1 will get you a full set, left & right.
Offline megaforce
« Reply #23 on: Tue, 14 March 2017, 15:31:01 »
Are we expecting any orders from our Korean friends? Saw zypher posted that a number of them were interested.
Offline KetchyKech
« Reply #24 on: Tue, 14 March 2017, 16:13:13 »
thanks sir~ !
Offline alienman82
« Reply #25 on: Tue, 14 March 2017, 18:13:20 »
removed.
« Last Edit: Thu, 01 March 2018, 13:03:41 by alienman82 »
Offline bendrexl
« Reply #26 on: Wed, 15 March 2017, 12:15:18 »
Price update: I was able to lower the minimum qty for the Oak bulk price to 4, so the realtime chart now reflects that price drop.
Offline bendrexl
« Reply #27 on: Thu, 16 March 2017, 14:30:17 »
We've crossed the 20 MOQ  :thumb:, so prices will start dropping incrementally for all styles as orders come in!
Offline zacheadams
« Reply #28 on: Thu, 16 March 2017, 15:43:36 »
Yuuuuuuuus!  One week left to go, cmon everyone, step right up and get yer beautiful VE.A wrist rests!!
Offline KetchyKech
« Reply #29 on: Mon, 20 March 2017, 07:45:39 »
In  ;)
Offline alienman82
« Reply #30 on: Mon, 20 March 2017, 11:32:08 »
removed.
« Last Edit: Thu, 01 March 2018, 13:02:52 by alienman82 »
Offline zacheadams
« Reply #31 on: Thu, 23 March 2017, 21:17:45 »
In  ;)
Thank you for your order!
What's the status of the Black Walnut & Padauk etc. people?  Can they get notified that they need to change over their order or drop (re: MOQ)?
What's the general status of when invoices will go out (I assume during or after that concern is resolved)?
Offline bendrexl
« Reply #32 on: Fri, 24 March 2017, 00:43:11 »
No need to switch, those woods species just haven't hit their individual bulk pricing.
We will fill those orders at the current price shown on the chart - they still benefit from the overall cost share savings.
Offline zacheadams
« Reply #33 on: Fri, 24 March 2017, 07:09:57 »
Ah okay ^^
Thanks again to you and alien for doing this, I'm excited to receive my invoice and wait patiently (read: frantically) see the end product.
Offline litster
« Reply #34 on: Fri, 24 March 2017, 13:07:04 »
I just received this email, it isn't clear if it is for this group buy.  Any idea?
Sent: Friday, March 24, 2017 10:04 AM
Subject: VE.A GB confirmation - need forum user name
Greetings!
We're wrapping up the group buy, and since you were an "early backer" we don't have a public / forum user name for you (we added that field to the form later).
Would you please reply to this message with your forum / reddit / whatever user name so I can update your order?
Thanks for helping make this happen!
- Ben (bendrexl)
« Last Edit: Fri, 24 March 2017, 17:52:53 by litster »
Offline alienman82
« Reply #35 on: Fri, 24 March 2017, 13:08:13 »
removed.
« Last Edit: Thu, 01 March 2018, 13:02:09 by alienman82 »
Offline MandrewDavis
  • Chasin' That Neon Rainbow
« Reply #36 on: Fri, 24 March 2017, 13:12:39 »
Forgot about this, guess its do or die time  :-\
I've come to view humanity as predominantly monkey business.
My Classifieds Thread
Offline Data
« Reply #37 on: Fri, 24 March 2017, 13:14:03 »
Greetings!
- Ben (bendrexl)
Yes it's for this group buy.
You can't tell litster by his wood species preference?  Come on!
« Last Edit: Fri, 24 March 2017, 21:27:11 by trizkut »
Offline bendrexl
« Reply #38 on: Fri, 24 March 2017, 14:54:48 »
yeah, I should have known ;)
(if a mod happens by, would you mind removing my email addy from the above quotes? Hate to make things too easy for the spambots, right?)
Offline FoC_Tow
  • Brokehlicious
« Reply #39 on: Fri, 24 March 2017, 15:19:29 »
Still trying to make up my mind about wood color over here tbh.
Loving the zebra wenge combo, but wondering if it would go well with a gray wooden desk.
In the sample pics black walnut looks fully gray to me, but finishing seems to add a brownish tint to it.
Is the tint really a result of the finish?
Would I be able to get a raw black walnut, and would adding s clear finish maintain the gray color?
Offline bendrexl
« Reply #40 on: Fri, 24 March 2017, 16:00:01 »
Yes, you're exactly right - the raw wood looks flat gray, and any finish will amplify more of the underlying color, no matter the wood. Oil-based finishes tend to penetrate deeper, and make the color deeper / warmer (which is usually exactly what you want).
A water-based finish is an option - these don't penetrate as much and affect the color less, though it still won't be grey. Stained oak could be a possibility also.
Offline FoC_Tow
  • Brokehlicious
« Reply #41 on: Fri, 24 March 2017, 16:14:24 »
Thx for the quick reply bendrexl! =)
So you suggested getting a raw oak and doing a gray stain on it, correct?
Incase I'll choose to try this, would it be possible to get one of the cutting left overs as shown in pic 7 to test stains on by any chance? xD
Offline litster
« Reply #42 on: Fri, 24 March 2017, 17:55:00 »
Sorry about including your email address.  I remove it from my post.  if other people who quoted me could do the same, that would be great.
Offline bendrexl
« Reply #43 on: Fri, 24 March 2017, 17:57:56 »
If you have a specific effect in mind and are trying to match something, I'd look around for some other projects for some real-world example photos.
Since I'll be packing them up myself, that should be doable. I'll have lots of those bits around ;)
Offline FoC_Tow
  • Brokehlicious
« Reply #44 on: Fri, 24 March 2017, 18:30:11 »
I went with black walnut & maple. =)
If possible I would like to get a completely raw and unfinished version, and a few cutting leftovers to test with please.
Thx for the help again bendrexl!
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
« Reply #45 on: Fri, 24 March 2017, 21:12:28 »
Tough choices, gonna go with the Wenge w/ Padauk.
« Reply #46 on: Fri, 24 March 2017, 22:21:46 »
Screw it. I'm in this for ya buddy.
Offline bendrexl
« Reply #47 on: Fri, 24 March 2017, 23:16:19 »
Noted; we'll make it happen - yours will be truly custom!
An excellent choice, that's a striking combo.
Welcome to GB, I've been dying to get wood ordered and kick this into high gear.
Any last minute undecideds better get on it before alienman closes the polls, last chance!
Offline megaforce
« Reply #48 on: Sat, 25 March 2017, 00:03:49 »
Totally a potato when it comes to woodworking, but what type of finish will these be? Matte or gloss?
Offline alienman82
« Reply #49 on: Sat, 25 March 2017, 00:47:19 »
removed.
« Last Edit: Thu, 01 March 2018, 13:02:06 by alienman82 »
