Author Topic: New to geekhack and the keyboad world  (Read 2650 times)
Offline poGDI
« on: Wed, 08 March 2017, 06:14:56 »
Hello!
My name is Jimmie and I'm from Sweden. I'm really new to the world of customizing keyboards. I used to have one of those OLD mechanical keyboards back in the early 90's and I really miss them. So it's time to build two new keyboards, one for work and one for home.
That brought me here, I hope I can get all the answers and help that I want here.
/Jimmie
Offline Mechboards
  • Mechboards UK
    • Mechboards
Re: New to geekhack and the keyboad world
« Reply #1 on: Wed, 08 March 2017, 06:24:24 »
Welcome! Any questions ask away.
Offline poGDI
« Reply #2 on: Wed, 08 March 2017, 06:55:11 »
Thanks,
Is this the correct place to ask? I'l make a small question here and move it to an other thread if its not ok. :)
I'm looking for a 88-keycaps keyboard, want a small one but I need those F1-F12 keys. I want a OK keyboard to start with that I can customize with my own caps and so on. Should be ISO (swedish) compatible.
Something like this one maybe: https://www.massdrop.com/buy/godspeed-custom-sa-keycap-set but maybe without the extra keys to the right :) Not 100% sure what I'm looking for, price and feel need to match.
Offline hking0036
« Reply #3 on: Thu, 09 March 2017, 10:50:42 »
Thanks,
Those are just keycaps, no board underneath. As for keyboards there's plenty of solid ten keyless boards out there, but iso support is kind of slim both in terms of cap sets and manufacturers. I do think you can get a Filco majestouch 2 in iso but I'm not sure. That's a good place to start though, Filco boards are supposed to be built pretty solidly.
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
Offline seville57
« Reply #4 on: Thu, 09 March 2017, 12:25:10 »
Välkommen/welcome
You have some ISO/Swedish/Finnish Filco TKL k - boards here: http://www.keyboardco.com/keyboard/filco-majestouch-2-tenkeyless-nkr-mechanical-keyboards.asp
« Last Edit: Thu, 09 March 2017, 12:33:28 by seville57 »
Offline darbysuperhack
« Reply #5 on: Thu, 09 March 2017, 12:48:59 »
Thanks,
Another option would be a 75% like KBT (Vortex) Race II... Kinda a little more difficult to find custom keycaps for, but they cut down on space with almost the same amount of keys as a TKL... Here is a good link with a lot of different options listed. Some of them are not always available... https://www.massdrop.com/vote/Best-75-Mechanical-Keyboard?mode=guest_open
Edit: looks like most of them that are available online are not available in ISO format... not sure which ones are. You may have to be willing to build a Korean custom like winkeyless.kr b.mini.
« Last Edit: Thu, 09 March 2017, 12:58:26 by darbysuperhack »
