Author Topic: Custom case for PCB-mount Planck build  (Read 1943 times)
Offline Dvoraknolegends
« on: Thu, 09 March 2017, 17:33:47 »
Hi,
I'm getting the Planck as my mobile, portable go-everywhere keyboard, and I'd like to build it PCB-mount, without the plate, which /u/jackhumbert told me is possible with a custom case. Has anyone come across a PCB-mount case for the Planck?
« Last Edit: Wed, 29 March 2017, 00:43:37 by Dvoraknolegends »
Offline Phenix
Re: Custom case for PCB-mount Planck build
« Reply #1 on: Fri, 10 March 2017, 09:31:49 »
Woodq base plate+wooden side walls with the pcb screwed in.
Winter is coming.
« Reply #2 on: Fri, 10 March 2017, 10:05:38 »
Did you build it yourself?
Offline Phenix
« Reply #3 on: Fri, 10 March 2017, 11:00:31 »
yes. https://www.dropbox.com/s/n4qlodcrso0rzk1/20170224%20SA%20RETRO.jpg?dl=0
heres an picture of my 66% build
Gesendet von meinem Moto G (4) mit Tapatalk
Winter is coming.
