Author Topic: SSL Keyboard DB9 help!  (Read 10586 times)
Offline Half-Saint
« on: Mon, 08 February 2010, 15:53:04 »
A while ago I picked up this keyboard labeled Solid State Logic (Rotec International Ltd. Made in UK). It looks a lot like Cherry G81-1800. It's a clicky keyboard and uses blue Cherry switches. The PCB is Cherry, dated 1992. On the bottom of the case there's a hole where a PC AT switch is supposed to be but it's obvious that the PCB has no connection points for the switch. There's a Philips PCB80C31BH chip in there as well as Texas Instruments SN75179BP (apparently a RS-422 differential transceiver). Cable connector is standard DB9 instead of PS/2.
Anyone know what this was used for and, if it can be modded for use with a standard PC?
Cheers,
SainT
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline lal
« Reply #1 on: Mon, 08 February 2010, 16:26:33 »
Can't help you, but that case color looks nice.  Reminds me of industrial Ms.  Hope you'll get it to work :)
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline itlnstln
« Reply #2 on: Mon, 08 February 2010, 16:30:14 »
Hmm.  Industrial Cherry G(80)s.  I like the sound of that.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #3 on: Mon, 08 February 2010, 16:41:00 »
Nitpicking...but technically that is a DE9 shell, not a DB. DB is the size used by parallel and 25-pin serial ports.
Interesting keyboard for sure though.
kishy.ca
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #4 on: Mon, 08 February 2010, 17:31:54 »
Some sort of serial keyboard for industrial applications for sure. RS-485 is not uncommon for longer-range serial connections. Older G80-1000 PCBs (with 8051) also had space for such a transceiver chip... seemingly for some synchronous serial interface. I'd guess that would have required the different controller IC (8031 with EEPROM) as well.
You might be able to make/buy a RS-485 <-> RS-232 adapter and use the board with that, though I'm not sure how these serial boards want to be treated software wise.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #5 on: Mon, 08 February 2010, 17:32:03 »
That thing ought to be PS/2 compatible with a cable swap.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #6 on: Mon, 08 February 2010, 17:41:22 »
Quote from: microsoft windows;157128
Dangerous words...I see no reason why that's possible at this point in time.
What makes you think so?
kishy.ca
« Reply #7 on: Mon, 08 February 2010, 18:40:09 »
It looks to be the same model as a wide variety of other Cherry keyboards. It looks to be something that was used on an early "luggable" computer, so I wouldn't be surprised if it's AT compatible.
Offline pfink
« Reply #8 on: Mon, 08 February 2010, 20:24:10 »
Quote from: Half-Saint;157112
If it's the same Solid State Logic as this:
http://www.solid-state-logic.com/
then maybe it was originally sold with some type of recording studio equipment.
Offline InSanCen
« Reply #9 on: Mon, 08 February 2010, 23:58:04 »
Regarding a cable swap.
The only way to know for sure is to compare the controller and circuit to a known PS/2 keyboard, in this case a G81-1800. Mine is in work, so I can't, even if we had pictures suitable for doing it. Unless it is the same, then there is a good chance you are going to fry something with a cable swap. While I wouldn't be surprised if it is compatible, I wouldn't want a member doing it and frying it based on my Gut feeling or Wild Ass Guess.
Just be careful with what you are saying.
*sigh*
MS Windows is on my ignore list, but I still see his stupidity if other people Quote him.
EDIT:-
That link pfink gave is a great way for InSanCen to waste hours. I aspire to setups like that, and makes my "little" 16ch Alesis mixer look quite crap in comparison. I did spot a CST Trackball though. Shame about the abundance of Mac chicklet boards.
http://www.solid-state-logic.com/resources/gallery/Matrix/Matrix_South_Beach_Studios_large.jpg
http://www.solid-state-logic.com/resources/gallery/c200/c200main/c200main6.jpg
« Last Edit: Tue, 09 February 2010, 00:22:00 by InSanCen »
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline Half-Saint
« Reply #10 on: Tue, 09 February 2010, 01:38:58 »
Here's the connections from cable to PCB...
Black - GND
White - Vcc
Yellow..Red - connected to SN75179BP outputs (pins 5-8 or A,B,Z,X)
I don't think this would work with PS/2. Looks like there are no dedicated CLK or DATA lines...
SainT
[SIGPIC][/SIGPIC]
Offline erricrice
« Reply #11 on: Tue, 09 February 2010, 12:23:41 »
Quote from: InSanCen;157178
EDIT:-
Pshhh, silly 48 channel setups, 56 is the way to go!  That way you get 8 channels for dedicated effects sends!
Take a look at what I get to work on every day!
Keyboard built in and everything!
« Last Edit: Tue, 09 February 2010, 12:25:54 by erricrice »
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline itlnstln
« Reply #12 on: Tue, 09 February 2010, 12:34:46 »
Lucky bastard, that's an awesome studio.  That's a sweet sound room, too.  I like the acoustic treatment on the walls.
Offline erricrice
« Reply #13 on: Tue, 09 February 2010, 12:58:17 »
Quote from: itlnstln;157336
Take a look!
We're still working on the website, but the studio is up and running!
Logitech G5[/FONT]
Offline itlnstln
« Reply #14 on: Tue, 09 February 2010, 13:00:53 »
That's sick.  I would love to get back into the music scene again.  That was a lot of fun.
Offline lal
« Reply #15 on: Tue, 09 February 2010, 13:03:54 »
Excuse me, are those pics all 3D renderings?
Offline InSanCen
« Reply #16 on: Tue, 09 February 2010, 13:04:58 »
How much would I be looking at to hire that out? (Not that I could or would, just curious).
In all honesty, the 16channels I have at the moment are overkill (One guitar hookup, one vocal). The rest are there if needed. Most of my stuff is done in the PC via an M-Audio Delta 1010 and Cubase/Abelton.
Still, it looks the business though. I would love to be let loose in there for a few hours.
Quote from: erricrice;157326
Offline erricrice
« Reply #17 on: Tue, 09 February 2010, 13:13:42 »
Quote from: lal;157351
The pics on the website, yes as of now, I'm in the process of uploading the new photos to the website.
The one I posted here, no that is a real photo, taken professionally.
Logitech G5[/FONT]
Offline erricrice
« Reply #18 on: Tue, 09 February 2010, 13:25:38 »
Quote from: InSanCen;157353
The room rate(no engineer) is $100 /hr, and for the engineer, add $50 /hr.
For basic stuff, 16 channels IS overkill, but it's good that you have it so you have the room to move up if you want.
We're working with 48 channels of Digital to Analogue I/O with 3 Protools HD Cards.  Kinda crazy.
And yes, I feel privileged as hell working with this setup.  You can't make things sound bad, even if you tried lol.
...for a few hours.
A few hours is never enough...it's worse than keyboard addiction...
Logitech G5[/FONT]
Offline itlnstln
« Reply #19 on: Tue, 09 February 2010, 13:30:57 »
Yes you can.
Offline erricrice
« Reply #20 on: Tue, 09 February 2010, 13:35:08 »
Quote from: itlnstln;157357
Yes you can.
AAAAHAHAHAHAHHA
I stand corrected!
But for the record, we have a special system set up so that when anyone like that comes within a mile of the building, it zaps them.  It's kinda like a shock collar for dogs.....except it kills them....
Logitech G5[/FONT]
Offline Half-Saint
« Reply #21 on: Tue, 09 February 2010, 13:46:23 »
Now that's clearly hijacking a thread :P
[SIGPIC][/SIGPIC]
Offline erricrice
« Reply #22 on: Tue, 09 February 2010, 13:57:17 »
Quote from: Half-Saint;157359
Yeah sorry man, I was going to say that.  I will take my stuff to another thread.
Logitech G5[/FONT]
Offline In Stereo!
« Reply #23 on: Tue, 09 February 2010, 15:04:22 »
Is there any available music that has been recorded in this studio?
Offline InSanCen
« Reply #24 on: Tue, 09 February 2010, 17:35:52 »
Quote from: erricrice;157356
Not bad at all. Working with my last band, we paid 150GBP/hr, and engineered it ourselves. and it was a hole compared to yours. Lovely old desk though, great sound but a ***** to use.
My Alesis
Quite pathetic when you bring out guns like yours!
I used to have my 7 Synths hooked up to it as well (2 mono channels per synth, one Vocal on mono, one guitar on mono), but since I got the Delta 1010, it's just used if a few people come round to jam. That's not often, as my neighbours tend to get annoyed at anything being played.
There is no such thing as overkill. Despite what my missus says ("Why do you need 7 keyboards?").
True. It would take me at least a day to wrap my head round what that setup can do, let alone get a handle on the effects. The patch bay alone looks scary!
Offline ch_123
« Reply #25 on: Tue, 09 February 2010, 17:38:32 »
Yes you can.
I was tempted to outdo you by posting a tinyurl link to a Kesha video, but I don't hate you folks that much.
Offline erricrice
« Reply #26 on: Tue, 09 February 2010, 21:16:32 »
Quote from: In Stereo!;157369
We just started our first session yesterday, so not yet.  We are working on a 15 song album project for about the first month or so.
Logitech G5[/FONT]
Offline Half-Saint
« Reply #27 on: Thu, 18 February 2010, 04:59:19 »
To get back on topic.. anyone has any idea how to get this to work with a standard PS/2 PC? Could it be done without switching the whole board?
Cheers
[SIGPIC][/SIGPIC]
Offline InSanCen
« Reply #28 on: Thu, 18 February 2010, 14:51:39 »
Quote from: Half-Saint;159086
Cheers
Assuming it is using a proprietary interface (fairly likely), then you will need to trace the matrix and design a controller for it. If you *really* like the board, it may be worth it.
Offline Half-Saint
« Reply #29 on: Fri, 19 February 2010, 02:07:32 »
Bah, I'll see.. in case I decide to get rid of it, would anyone buy it for the switches/keycaps? It has blue Cherry switches...
Cheers
SainT
[SIGPIC][/SIGPIC]
Offline 42.tar.gz
« Reply #30 on: Fri, 19 February 2010, 09:49:01 »
Quote from: Half-Saint;159313
I'd be interested. :)
Currently using: some keyboard
Offline ricercar
  • mostly abides
« Reply #31 on: Fri, 19 February 2010, 14:10:14 »
me! me! Oh wait. I'm too late and on the wrong side of the Atlantic.
Offline Half-Saint
« Reply #32 on: Fri, 26 February 2010, 02:03:26 »
Sold!
[SIGPIC][/SIGPIC]
Offline Half-Saint
« Reply #33 on: Mon, 12 April 2010, 06:45:35 »
Now that I have a real Cherry MX1800 it occured to me that it would look really cool, if I swapped cases! Too late now :)
[SIGPIC][/SIGPIC]
