Author Topic: Help Identify RGB LED for Viper V760  (Read 1476 times)
Offline rapper4u
« on: Sun, 12 March 2017, 04:17:46 »
Hi,
Recently one of my LED's from my V760 keyboard has stopped lighting green. I've opened up the keyboard and checked the LED and it's blown, i'm looking for a replacement but i can't seem to find one anywhere. So if anyone knows where i can find one or the part number of the LED (if they have one) please let me know. The LED is in the picture attached.
Offline Tactile
Re: Help Identify RGB LED for Viper V760
« Reply #1 on: Sun, 12 March 2017, 21:44:10 »
REΛLFORCE
Offline cutterline
« Reply #2 on: Sun, 12 March 2017, 22:08:01 »
Well, you might need to figure the pin configuration out first or you might get wrong color.
For example the one that Tactile gave, has 1- Red; 3-Blue; and 4-Green, whilst this one, just for example has 1-Red; 3-Green; and 4-Blue. You can test it using multimeter or 3V battery in line with resistor. Maybe you can contact the manufacturer to ask the rgb pin configuration.
Offline rapper4u
« Reply #3 on: Tue, 14 March 2017, 12:28:01 »
Thanks for the answers. Yes the first led is not the one i need as the 3 pin is Green for my LED that is the color that burnt from that LED.
I will try to contact the manufacturer and see if i can get something but i doubt it.
Maybe someone did an custom keyboard with these kind of LED's ?
