Author Topic: desoldering single Matias switch on Planck  (Read 2159 times)
Offline zutroy
« on: Sun, 12 March 2017, 07:34:12 »
Is it possible to remove a single Matias switch from a Planck without desoldering every switch on the board? All I've been able to find via Google searches is that this should be possible with MX switches on a universal plate. I haven't been able to find any documentation or videos about Matias switches, though. Follow up question, how would one determine if their Planck has a universal plate or not?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: desoldering single Matias switch on Planck
« Reply #1 on: Sun, 12 March 2017, 07:36:18 »
Yeah, you should be able to desolder just one switch and push it out of the mounting plate.
Offline zutroy
« Reply #2 on: Sun, 12 March 2017, 07:37:17 »
Excellent, thanks for the response!
Offline cutterline
« Reply #3 on: Sun, 12 March 2017, 20:57:17 »
In case you don't know about this, alps switch top can be removed for switch maintenance without the need of desoldering. On the other hand, MX switch needs cutout for top removal without desoldering.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #4 on: Sun, 12 March 2017, 23:32:24 »
Yup, +1
I was going to say the same thing... if a switch isnt working, you can try to swap out the top or just re-flow the solder joint with out pulling it out of the PCB.
-Dana
