Author Topic: Have issue with SA keycap on Filco spacebar  (Read 2495 times)
Offline DuckNorris
« on: Mon, 13 March 2017, 10:44:30 »
So I had an issue with a SA spacebar fitting on a Filco. What I did upon reading was tape 2 small strips of tape to each of the little white crosses (stabilizers?) and pushed the spacebar on top. It has not wiggled or anything after doing so but my question is will this mess up the spacerbar inserts? Should I have just gotten bigger stabilizers(white cross thingies?)
Thank you
Re: Have issue with SA keycap on Filco spacebar
« Reply #1 on: Mon, 13 March 2017, 10:46:02 »
It shouldn't hurt anything that is the typical fix for any issues with costar stabilizers that don't fit correctly.
You can also use small pieces of plastic bag material to do the same.
Offline Delirious
« Reply #2 on: Mon, 13 March 2017, 10:51:07 »
SP's mx stems are known to fit loosely on switches. Not just SA but their dsc and dsa lines also have loosed inserts
Offline DuckNorris
« Reply #3 on: Mon, 13 March 2017, 10:58:31 »
I tried 2 small pieces (and 3) of the plastic bag and did not work so I went with the tape. It kept wobbling quite weirdly.
Offline DuckNorris
« Reply #4 on: Mon, 13 March 2017, 11:04:34 »
Do you or anyone else happen to know if people do the same for the modifiers with stabilizers in them?I only did it for the spacebar but was wondering if I should do it for those too.
Offline Delirious
« Reply #5 on: Mon, 13 March 2017, 11:35:13 »
Yea I taped all of them. Some of the inserts were so big even mx clears feel loose
Offline DuckNorris
« Reply #6 on: Mon, 13 March 2017, 12:34:37 »
Ah all right that sounds pretty good I will go ahead and do the same! First SA kit so I am super stoked. Also, no one every does this for the regular alphas that only have the switch correct? (they feel fine for me) Only for the ones with stabilizers?
