Author Topic: Assistance with Preonic  (Read 1720 times)
Offline mniels
« on: Mon, 13 March 2017, 18:38:29 »
Well, I made a bonehead mistake and tried to flash the Preonic with the software that only works with the Planck.  As a result, it is currently bricked.  The computer recognizes it as a USB device when you plug it in, but no backlight, and no key recognition.  The only advice I got on the OLKB board on Reddit was to unplug it then plug it back in.  Not very helpful.
Any help with getting this guy back to at least the default settings?
Offline FRGMNT
Re: Assistance with Preonic
« Reply #1 on: Mon, 13 March 2017, 21:56:48 »
Have you tried the reset button on the back and then flashing properly?
Offline mniels
« Reply #2 on: Tue, 14 March 2017, 10:24:28 »
I think that the problem is the device protection:
