Author Topic: Replace a keyboard controller  (Read 3400 times)
Offline sorin
« on: Tue, 14 March 2017, 04:40:11 »
Hi guys!
What do you think is the easiest way to replace the controller of a keyboard that suffers from chattering?
Offline joey
Re: Replace a keyboard controller
« Reply #1 on: Tue, 14 March 2017, 04:45:59 »
It's likely to be the switches, not the controller that has the issue.
Offline sorin
« Reply #2 on: Tue, 14 March 2017, 04:54:38 »
It`s a Natec Genesis RX88. All the problems that I heard about this model were controller related.
It has cherry mx black switches. I got it for the price that I could have payed for the desoldered switches anyway...
Offline sorin
« Reply #3 on: Wed, 15 March 2017, 03:03:59 »
 Any ideas?
Offline Malachor
« Reply #4 on: Wed, 15 March 2017, 03:47:13 »
What do you mean by chattering?
Offline joey
« Reply #5 on: Wed, 15 March 2017, 03:50:01 »
Any ideas?
I think it's the sort of question where if you have to ask how difficult it will be.. it will be too difficult.
Offline sorin
« Reply #6 on: Thu, 16 March 2017, 08:12:34 »
Chattering is when you press a key and it writes it more then once.
My idea is to use another controller and rewire the tracks to the new one.
Offline kolec94
« Reply #7 on: Thu, 16 March 2017, 08:48:02 »
pretty much what you would need to do
or try a usb to usb keyboard adapter to try to deal with it
« Last Edit: Thu, 16 March 2017, 13:51:46 by kolec94 »
kbparadise v60 blues
