Author Topic: Hello!  (Read 1581 times)
Offline wangledorf
  • Formerly pewing
Hello!
« on: Tue, 14 March 2017, 12:07:42 »
Hey everyone, just joined GeekHack after lurking for a little while so I figured I'd introduce myself. I'm a software developer and a gamer. I've been into mechanical keyboards for a while and my current arsenal is:
* CM Storm (First mkb)
* Corsair Vengeance
* Code Keyboard (MX Clears)
* Pok3r (MX Clears, miami caps)
* Kinesis Advantage
Unfortunately, after using my Advantage it's hard going back to anything else except for gaming. So, most of my posts on here will probably be related to modding the Advantage.  My first projects will probably be to replace the built-in USB cable with a mini USB port so I can use detachable custom cables, replace the caps with PBT caps, and maybe replace the switches with clears or ergo clears.
Offline reaper
Re: Hello!
« Reply #1 on: Thu, 16 March 2017, 20:17:27 »
Welcome aboard!  :)
Din Eli
