Author Topic: Does clipped stabs make your spacebar wobbly?  (Read 2709 times)
Offline ArchDill
« on: Wed, 15 March 2017, 21:49:09 »
I am one of the community members that has still not built my own keyboard. I buy boards that other people have built. So far, all custom boards I have bought have had something wrong with it. First one had some switches soldered in crooked and the stabs were a bit messed up. 2nd one had some more crooked switches. The 3rd (and current) is ALMOST perfect. All of the switches are straight. However, my space bar tends to stick up and slanted to the right VERY SLIGHTLY. You may not notice unless I pointed it out. The stabs are clipped and lubed and I was wondering if that could play into it at all? It feels a lot more wobbly than any of my other boards. I THINK the stabs are cherry knock offs. I have taken it off and attempted to adjust to no avail.
I was going to attach a picture but you can not see it in the picture.
« Last Edit: Wed, 15 March 2017, 21:52:24 by ArchDill »
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: Does clipped stabs make your spacebar wiggly?
« Reply #1 on: Wed, 15 March 2017, 21:49:50 »
Just buy a stock Realforce, you don't have to mod anything..
Offline ArchDill
« Reply #2 on: Wed, 15 March 2017, 21:53:04 »
I have a Realforce 87u 55g on the way!
I am dome swapping it though...
Offline digi
  • elite af tbh
Re: Does clipped stabs make your spacebar wobbly?
« Reply #3 on: Wed, 15 March 2017, 21:53:39 »
You're already ahead of 90% people on this forum! GRATS
« Reply #4 on: Wed, 15 March 2017, 23:50:57 »
Never had an issue like that with clipped stabs.
Offline kasakka
« Reply #5 on: Thu, 16 March 2017, 08:46:15 »
That's the problem. Those knockoff stabilizers are frankly rattling pieces of ****. I replaced mine with Zealio stabs and they are clipped as well. No problems.
Offline kiwi99
  • that's a gnarly dookie
« Reply #6 on: Thu, 16 March 2017, 09:40:38 »
Someone I follow on instagram recently made a post about the different kinds of stabilizers you can see here out there https://instagram.com/p/BRqsfmzjAOh/
I personally bought some knockoff ones recently and oh my they are horrible. Wire is too thin so they rattle, stem is too small for the housing so they're all over the place. Depending on your board you might be able to easily swap them out even if you don't have a soldering iron and it might improve the feel of them.
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #7 on: Fri, 17 March 2017, 17:48:04 »
I have 2 boards that i hate the stabs on.. my sentraq and my new smart68. They rattle like crazy and ruin the feel of the board for me. I've clipped them, lubed them, taped them, rubber o-ringed them... still not even close to my ducky or topre or leopold. No idea what the deal is at this point.
-Dana
