Author Topic: Hydro Dipping / Water Transfer Printing Keycaps  (Read 5190 times)
Offline monojira
« on: Thu, 16 March 2017, 04:24:46 »
So I've been having the idea of hydro dipping some of my spare spacebars to give them a new appeal.
Online you find many tutorials and it seems to be an affordable and interesting way to modify your gear. I understand that most people here that did hydro dipping probably did so to their casing and not to the caps themselves.
One guide I found mentioned that of all plastics, ABS is the savest to use as it will keep the paint without flaming off the plastic.
I think I'd be pretty much good to go to give it a try but before I do I have two questions:
- Would you sand the caps lightly before dipping?
- What would be a good, not too glossy spray finish to protect the print? I was thinking of standard clear finish as you would get it for general paint projects / miniatures but I want to avoid a surface that is too smooth or glossy.
I definitely want to experiment around and test durability of the paint.
Offline TalkingTree
    • My projects
Re: Hydro Dipping / Water Transfer Printing Keycaps
« Reply #1 on: Thu, 16 March 2017, 05:31:14 »
The YouTube tutorials I've watched recommend to meticulously clean the plastic surface before dipping. No finish of sorts was used in the process.
Offline monojira
« Reply #2 on: Thu, 16 March 2017, 05:34:49 »
Hmm yes that confirms what I've been hearing too. Just soap + dry before applying the paint. I do feel like I want to add a finish for savety. I am definitely going to give it a try soon and do some testing.
I could try to get a decent comparison over 2-3 months w/ and w/o finish.
Offline TalkingTree
    • My projects
« Reply #3 on: Thu, 16 March 2017, 06:19:09 »
I don't know where in the world you live but this gentleman in Spain has some good offers.
Please show your results.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #4 on: Fri, 17 March 2017, 21:46:55 »
Would love to see how this turns out. Some hydrodipped caps could be really cool.
