Author Topic: LeandreN Mekanisk's Projects  (Read 106783 times)
Offline Davyb123music
  • "Music is the Best"- FZ
Re: LeandreN Mekanisk's Projects
« Reply #50 on: Sun, 18 June 2017, 12:24:18 »
Do you have any plans to make a 96layout case? Perhaps one similar to TX CP
I second that.  A "Simple" 96layout in gunmetal grey, would be an immediate buy from me.
Probably 2 of them.   :thumb:
« Last Edit: Sun, 18 June 2017, 12:27:45 by Davyb123music »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #51 on: Thu, 22 June 2017, 15:07:34 »
Offline E3E
« Reply #52 on: Sat, 24 June 2017, 07:57:13 »
Similar to the LZ-CE
Offline DanielT
« Reply #53 on: Sun, 25 June 2017, 08:33:03 »
I think I've said it everywhere, but this case is so cool. Love the simple look!  :thumb:
Can't wait for it to be available.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #54 on: Tue, 27 June 2017, 13:59:39 »
Thanks DanielT, glad you like it!
Offline xantiema
« Reply #55 on: Tue, 27 June 2017, 14:10:29 »
What layout is this concept?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #56 on: Tue, 27 June 2017, 18:28:32 »
Offline Fausuto
« Reply #57 on: Tue, 27 June 2017, 19:01:49 »
Omg! I want!
Sent from my HTC One_M8 using Tapatalk
Offline Cocopah
  • Lurker Extraordinaire
« Reply #58 on: Tue, 27 June 2017, 19:06:31 »
Offline E3E
« Reply #59 on: Tue, 27 June 2017, 19:50:11 »
Now that's pretty :D
Offline Applet
« Reply #60 on: Fri, 30 June 2017, 06:25:19 »
Do you have any plan for when the buy for the simple case will happen?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #61 on: Sat, 01 July 2017, 04:55:14 »
Trying to make it available soon, regardless of the progress of the other cases at the moment.
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
« Reply #62 on: Mon, 10 July 2017, 17:55:13 »
Love this top mounted design! Really glad I held out for r2 =D
Offline PotatoTM
« Reply #63 on: Thu, 13 July 2017, 02:10:25 »
would adding 2 additional screws in the center of the long sides give it additional support or make a difference? I heard the main problem with top-mounted plates is the "pinging"?
Regardless I am still very excited to see this one happen!
Offline pomk
« Reply #64 on: Thu, 13 July 2017, 06:19:44 »
I don't think that it would matter in this case, as the plate is fully supported on all sides. What could be done is to add a thin rubber gasket all around that would kill even the miniscule vibrations. Or just use a thick wooden plate for superior acoustics and feel.  ;)
Offline robotsokk
« Reply #65 on: Thu, 13 July 2017, 15:52:57 »
Pardon the question if it's dumb, but would the HHKB layout blockers exist for the top-mounted/pro version only?
@home      @work Swapping out boards... coming soon     wtb
« Reply #66 on: Fri, 14 July 2017, 00:45:52 »
Unless you want to design a PCB with cutouts, that's correct.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #67 on: Sat, 15 July 2017, 18:40:55 »
Design checklist for FJELL R2 topmounted(name to be redefined)
  • model
  • plate intergration
  • screws
  • HHKB top portion
  • top portion
  • chamfer adjustments
[] usb hole placement
[] weight design
[] sample
[] group buy
Design checklist for FJELL R2 traymounted(name to be redefined)
  • model
  • screws
  • HHKB top portion
  • top portion
  • usb hole placement
[] adjust screw placement
[] weight reworks
[] sample
[] group buy
Design checklist for Simple 60% "Elv" (name to be redefined)
  • overall design
  • screw hole placement
  • usb port placement
  • height and thickness
  • first sample ordered and reviewed
  • second sample ordered
[] distribution
Offline duynguyenle
  • Personal text? What personal text???
« Reply #68 on: Sun, 16 July 2017, 15:04:50 »
  • model
  • screws
  • HHKB top portion
  • top portion
[] weight design
[] sample
[] group buy
  • model
  • screws
  • HHKB top portion
  • top portion
[] weight reworks
[] sample
[] group buy
  • overall design
[] distribution
Please don't run them all at the same time :(
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline PotatoTM
« Reply #69 on: Sun, 16 July 2017, 17:21:11 »
  • model
  • screws
  • HHKB top portion
  • top portion
[] weight design
[] sample
[] group buy
  • model
  • screws
  • HHKB top portion
  • top portion
[] weight reworks
[] sample
[] group buy
  • overall design
[] distribution
It would make sense for him to run the 2 FJELLs together, maybe the simple case could be ran separately
Offline amnesia0287
  • Formerly Amnesia
« Reply #70 on: Sun, 16 July 2017, 23:12:44 »
In some ways it makes sense. But I would probably buy more than 1 of both fjell if they didn't run at once... harder to do if they run together. I doubt I'm alone lol. Or people who want both but can only do one at a time. Even just confirming there will be R3 would work for some people I'd imagine.
Offline Atredl
« Reply #71 on: Mon, 17 July 2017, 05:30:58 »
Remember that it might still be a limited GB and buying more than one might not be an option.
Offline Pepe_Silvia
« Reply #72 on: Mon, 17 July 2017, 16:50:23 »
How many color options did the first fjell run have?
Offline Atredl
« Reply #73 on: Mon, 17 July 2017, 16:53:30 »
It had 6 anodizing colors (Black, Silver, Grey, Purple, Blue and Orange) and 2 weight options (Brass and Chrome plated steel)
Offline Pepe_Silvia
« Reply #74 on: Mon, 17 July 2017, 17:16:41 »
Has it been discussed if there will be that many colors this time around and if Elv case will get same amount of color options too?
Offline Atredl
« Reply #75 on: Mon, 17 July 2017, 18:03:36 »
No confirmation of any colors as far as I'm aware
Offline gnunin
« Reply #76 on: Sat, 22 July 2017, 03:12:43 »
Mountain/R2 in white. The dream.
Offline forevermadrigal
« Reply #77 on: Sat, 22 July 2017, 04:31:33 »
Super stoked for fjell r2, just hope I have the funds when the time comes around
Offline dante
« Reply #78 on: Sat, 22 July 2017, 11:29:32 »
Offline heyitsqi
« Reply #79 on: Mon, 24 July 2017, 12:13:06 »
Oh man can't wait.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #80 on: Fri, 28 July 2017, 16:17:58 »
Hello!
Some updates.
I have gotten a ton of emails and requests regarding the FJELL Group Buy, from you here and even other vendors. As of now, I can't handle enough orders to please everyone.
If I can find a vendor that is able to handle FJELL orders, I will be able to go that route. I will make sure it is safe for every participant. Manufacturing will go through my factory anyway. Everything will still be LeandreN style with Mekanisk branding, but it would allow me to have better fulfillment for more cases. This might change later, as Mekanisk grows.
Also, the simple case is ready for mass production very soon.
Any thoughts or concerns? Please let me know.
William
Offline pixelpusher
« Reply #81 on: Fri, 28 July 2017, 19:31:28 »
very nice, sir.  I'll take 2 simple cases and 2 Fjell when they are ready :)
One request for you... can you put a standard 60% PCB and plate in it?  I want to see the gap between the edges of the plate and the case.  The one popular case on ebay/alliexpress right now is very nice, but it has a lot of extra space once you put a board in it.  I'm hoping yours will be a tighter fit
« Last Edit: Fri, 28 July 2017, 19:33:24 by reececonrad »
Offline DanielT
« Reply #82 on: Sat, 29 July 2017, 00:50:40 »
Hello!
Some updates.
William
Great news! You know I like the Simple case a lot! Do you have some photos also of the bottom?
Regarding the vendor I only hope he is EU friendly  :thumb:
Offline robotsokk
« Reply #83 on: Sat, 29 July 2017, 12:43:32 »
Awesome to hear these updates.
Is the idea that, to start, the future vendor would run the FJELL orders as a group buy as well, or instead seek to do a run of some cases and then put those up for purchase like a regular item (and rinse/repeat)? Just curious.
Also, congrats LeandreN on the success and growing popularity of your work -- well-deserved, as your cases look great (and from the obsessive reading I've done of comments from folks that received their FJELL cases, everyone is very pleased with the results).
Offline shekki
« Reply #84 on: Tue, 15 August 2017, 18:23:57 »
I don't think I've wanted anything as much as I want the Fjell Pro Classic. Getting pre-raffle anxiety :))
Offline pixelpusher
« Reply #85 on: Tue, 15 August 2017, 18:32:57 »
Hello!
Some updates.
William
 I see a lot of people putting material in the bottom of metal cases to dampen the sound, but that doesn't actually do much.  What really changes the sound and feel is where the PCB meets the mounts.
I've always though about trying to source some different disc-like materials to go atop of the M2 screw posts to dampen the harshness of the metal case.  I was thinking a dense foam or medium density rubber, but I would want to experiment to see what sounds the best.
Have you ever tried anything like this?  If you could include them as a customization option (like people sometimes do with rubber feet), that would be awesome.
Fjell is still the top case out there in my opinion.
P.S.
I'd really like to see more acrylic or polycarb plates on the market.  I see that you are selling off some extras that you had.  Any chance that you'll be getting more in the future?  As you may be able to tell by now, I'm all about the feel of the board.  It makes me think twice when I switch from a nice custom with alum case back to an old quickfire rapid and realize the quickfire rapid actually feels nicer to type on :(
« Last Edit: Tue, 15 August 2017, 18:36:59 by reececonrad »
Offline duynguyenle
« Reply #86 on: Wed, 16 August 2017, 04:36:40 »
Hello!
Some updates.
William
P.S.
Actually, putting foam dampers into the bottom of the case will absolutely change the sound signature, assuming the foam layer is thick enough to touch the pcb. And even if it doesn't, it will make a difference if you're doing this modification on a lightweight plastic case which will reduce reverberations and resonation within the empty cavity
Offline funderburker
« Reply #87 on: Wed, 16 August 2017, 04:54:34 »
DAMN. Please make this case is dark/forest green. Already saving up for this to drop.
Keyboard design by Skepur
Offline pixelpusher
« Reply #88 on: Wed, 16 August 2017, 07:45:43 »
I agree with all of this.  However, I'm looking for a better "feeling" experience, so I'm less concerned with the sound than I am the feel of the board.  Dampening the case doesn't change the harshness of the vibrations you feel when you type, at least not that i could tell.  I've tried with 3 different aluminum cases now, and nothing seems to work without addressing the points of contact between the PCB and the chassis.
It was just a suggestion for a simple extra that might be awesome if it could be done on the cheap. I figured he would have access to materials and manufacturers that could make an oddball part an easy find.
Offline WCO1
« Reply #89 on: Wed, 16 August 2017, 16:51:33 »
Hello!
Some updates.
William
nice. really looking forward for this case.
« Last Edit: Wed, 16 August 2017, 16:54:01 by WCO1 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #90 on: Sat, 19 August 2017, 07:22:05 »
First priority now is making the Klippe case available. I might also run a GB myself for them.
My next will be to collaborate with a vendor on the Fjell classic and the Fjell pro.
Offline OnceSavedGaming
« Reply #91 on: Sat, 19 August 2017, 07:36:41 »
We the klippe case the "basic" and if so is there an estimated gb date? I don't want to buy the revo one if yours is coming out soon
Sent from my SM-G920V using Tapatalk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #92 on: Sat, 19 August 2017, 07:43:48 »
1upkeyboards.com will stock them at the MSRP $179 in some weeks. These will probably sell out fast. I will then look into starting a group buy for them.
Offline Shoah
« Reply #93 on: Sat, 19 August 2017, 07:46:05 »
Is there a rough estimate when the fjell pro will be available yet?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #94 on: Sat, 19 August 2017, 07:47:47 »
The design is very complicated, so I need to make sure everything is okay before I start production. I need to revise the files more.
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #95 on: Sat, 19 August 2017, 08:12:22 »
Anything for us in Europe ? I mean, you're from Europe yourself, do you know that hassle it is to import something from.the states and pay import fees :-/
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #96 on: Sat, 19 August 2017, 08:19:29 »
That is the main reason I plan on running it myself afterwards.
Offline JSaintS
    • JSaintS
« Reply #97 on: Sat, 19 August 2017, 08:21:40 »
perfect! Do you know if this will be a limited run GB (like X spot available) or just a normal GB?
Thanks a lot for your outstanding work!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #98 on: Sat, 19 August 2017, 08:28:28 »
These will be stocked and ran a lot to make them available. I don't think the GB will have to be limited.
Offline pixelpusher
« Reply #99 on: Sat, 19 August 2017, 08:43:31 »
Just saw the revo one on massdrop.  Despite the finish, wouldn't you say the two cases are very similar?  Any idea which one is thicker? I love thick side bezels
