Author Topic: Spirit FaceW compatibility question  (Read 1722 times)
Offline pixelpusher
« on: Thu, 16 March 2017, 15:51:52 »
Wondering if anyone out there has placed a FaceW PCB in one of the fat lipped tex cases (that have support bars).  Need to know if they are compatible.
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1618
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1351
Re: Spirit FaceW compatibility question
« Reply #1 on: Thu, 16 March 2017, 15:55:02 »
facew is a poker PCB so it should work
Offline pixelpusher
« Reply #2 on: Thu, 16 March 2017, 16:07:06 »
To be more clear, what I'm worried about is the diodes on the back coming into contact with the metal horizontal supports in that particular case. I used the acrylic version of that case for my s60-x build and I had to dremel out some of the plastic where it was making contact with components on the back of the pcb.
It sounds like you're saying it should be exactly the same as a pok3r PCB though, so maybe it's not an issue.
« Last Edit: Thu, 16 March 2017, 16:08:43 by reececonrad »
Offline pixelpusher
« Reply #3 on: Thu, 16 March 2017, 16:22:04 »
