Author Topic: Coloring topre spacebar using iDye Poly  (Read 2405 times)
Offline dario
  • obsessive–compulsive hardware slut
« on: Thu, 16 March 2017, 22:40:49 »
Does anyone have any experience in trying to color topre PBT spacebars?
I know it works pretty well with regular 1U keycaps, but spacebar is a different thing. It's too long and it starts turning into clay even if you heat it up with a hairdryer, let alone boiling hot water.
I mean, it's difficult enough to find a perfectly straight PBT spacebar all by itself, but then trying to play with it at high temperatures seems like a risky business.
It is my experience that even extremely small variations in shape of the spacebar can make a difference between a good thock and irritating rattle.
Has anyone made any experiments?
Moreover, how does dye withstand constant wear?
What about UV resistance?
« Last Edit: Thu, 16 March 2017, 22:47:59 by dario »
Re: Coloring topre spacebar using iDye Poly
« Reply #1 on: Thu, 16 March 2017, 22:43:02 »
Nubbinator would know
« Reply #2 on: Thu, 16 March 2017, 23:27:10 »
Topre spacebar is ABS.  It will melt if you heat it.  You may be able to do iDye Poly that's lukewarm and let it sit for a while, but it's suboptimal.
Offline dario
« Reply #3 on: Thu, 16 March 2017, 23:34:28 »
I know what it is, but there are plenty of PBT topre spacebars around on the market. MD1, MD2, cheap ones from China etc.
