Author Topic: Costar Stabs  (Read 3570 times)
Offline Xevoxz
Costar Stabs
« on: Sat, 18 March 2017, 06:21:45 »
why they rattle? is it the wires? lmaoo its noisy af enter shift key backspace key have rattles is it normal for a Silent switch?
oh yeah when pressing on the sides both sides they are mushy
« Last Edit: Sat, 18 March 2017, 06:52:03 by Xevoxz »
Offline ghostjuggernaut
Re: Costar Stabs
« Reply #1 on: Sat, 18 March 2017, 07:27:43 »
You can lube the wire where it enters the clip, and it will normally get rid of the rattle.  As for mushy, mine have never felt mushy.  In fact, I prefer the feel of properly lubed costar stabs to cherry stabs.
« Last Edit: Sat, 18 March 2017, 07:33:11 by ghostjuggernaut »
Offline Xevoxz
Re: Costar Stabs
« Reply #2 on: Sat, 18 March 2017, 07:31:36 »
loop? or lube?
Offline Xevoxz
Re: Costar Stabs
« Reply #3 on: Sat, 18 March 2017, 07:31:55 »
You can loop the wire where it enters the clip, and it will normally get rid of the rattle.  As for mushy, mine have never felt mushy.  In fact, I prefer the feel of properly lubed costar stabs to cherry stabs.
loop? or lube?
Re: Costar Stabs
« Reply #4 on: Sat, 18 March 2017, 07:33:27 »
lube lol, not sure where loop came from.
Offline Xevoxz
Re: Costar Stabs
« Reply #5 on: Sat, 18 March 2017, 07:50:22 »
oil will do right? forgot to buy it when i was on wasdkeyboards lol shipping fee is kinda expensive
Re: Costar Stabs
« Reply #6 on: Sat, 18 March 2017, 12:36:29 »
Check shipping from Elitekeyboards or Techkeys, too.
Offline Hyde
  • White Tofu Extraordinaire
Re: Costar Stabs
« Reply #7 on: Tue, 21 March 2017, 15:31:05 »
Check if the plastic pegs on the side are seated properly.
Costar stabs should never feel mushy, only Cherry stabilizers are mushy (I can never use non-clipped Cherry stab again).
Also keep in mind when lubing, petroleum based greasy will eat away plastic.  Generally silicone based lube (like from elitekeyboards) are good.
