Author Topic: Difference between legends on AEK I and AEK II dye-sub caps  (Read 2632 times)
Offline Blazestorm
« on: Sat, 18 March 2017, 14:34:25 »
I bought a custom keyboard that came w/ AEK caps, I don't know what generation, but the legends are a bit thick.
Then I found an old AEK I in my family's garage. Turns out these legends are much sharper.
Anyone else notice this before?
Custom (AEK II?)
AEK I
I can take better pictures now that I got some sunlight.
Re: Difference between legends on AEK I and AEK II dye-sub caps
« Reply #1 on: Sat, 18 March 2017, 15:55:47 »
dyesub legends /do/ fade with use and age, that might have something to do with it
Offline Blazestorm
« Reply #2 on: Sat, 18 March 2017, 16:42:36 »
All of the legends are like this, even on keys that shouldn't have been used often (i.e. Scroll Lock), and AEK I would be older than AEK II... so it would have faded more
« Last Edit: Sat, 18 March 2017, 17:14:10 by Blazestorm »
