Author Topic: OMG Fake Ricecar SPOS on Ebay  (Read 4965 times)
Offline elbowglue
« on: Wed, 10 February 2010, 17:56:40 »
http://cgi.ebay.com/Cherry-POS-USB-Keyboard-Touchpad-Card-Reader-SPOS-G86_W0QQitemZ220553876256QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item335a091320#ht_500wt_975
This has the same item number G86-62410EUAGSA as the Ricecar SPOS, BUT look at the keys in detail - I think this is a rubber dome!  (nubs on the F and J, control and alt are not concave but convex like a dell rubber dome keyboard)
The horrors of Cherry naming system!
The sticker on the back does not have the article number G80-62410 on the back.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline Mental Hobbit
« Reply #1 on: Wed, 10 February 2010, 18:10:18 »
A Cherry made in China?
Typing on blues.
Offline ricercar
  • mostly abides
« Reply #2 on: Wed, 10 February 2010, 18:11:44 »
Faker! Charlatan! I am the original! Sacrilege!
Offline ricercar
  • mostly abides
« Reply #3 on: Wed, 10 February 2010, 18:42:32 »
I'm on the left, pouting, and he's the one with the hat.
Offline sethstorm
« Reply #4 on: Wed, 10 February 2010, 20:12:17 »
Quote from: elbowglue;157663
If it's the G86 qwerty equivalent of my SPOS G86-63410, I'd expect it to be such.  It's just another rubber dome.
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline elbowglue
« Reply #5 on: Wed, 10 February 2010, 20:18:33 »
I asked the seller to take a key off and tell me the color and shape of the keystem, it appears this is not an MX board.  What it is actually is not clear as his description was a little confusing to me, probably a rubber dome.  Not all G86-62410EUAGSA are Ricecar SPOS's.
Offline elbowglue
« Reply #6 on: Wed, 10 February 2010, 20:52:16 »
How to tell a rubber dome G86 vs MX G86-
Rubber domes have nubs on F and J
Rubber domes don't have concave Alt and Control buttons
Rubber dome spacebar slopes downward towards the front lip
Relegendable Keycaps on rubber domes (covered by clear plastic at the top of the KB) do not rise significantly above the lateral lip of the keyboard, whereas MX relegendable do.
Rubber domes:
http://cgi.ebay.com/Cherry-POS-USB-Keyboard-Touchpad-Card-Reader-SPOS-G86_W0QQitemZ390155039297QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5ad70d7241#ht_4683wt_932
http://cgi.ebay.com/WINCOR-NIXDORF-CHERRY-USB-POS-KEYBOARD-SPOS-G86-6140_W0QQitemZ180467717524QQcmdZViewItemQQptZBI_Cash_Registers?hash=item2a04b6d594#ht_837wt_958
MX boards:
http://cgi.ebay.com/Cherry-Brown-MX-Clicky-Keyboard-Mechanical-Programmable_W0QQitemZ190371088570QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item2c530048ba#ht_500wt_975
I think I'm right about these above.
If you are looking for the true ricecar SPOS, ask the vendor to check on the back to make sure it says "article no: G80-62410EUADSA"
Also the true ricecar SPOS has a Ferrite core near the USB plug, I believe the corresponding dome g86-62410EUAGSA does not.
Oh and mental hobbit is probably right, real ricecar spos looks to be made in USA, fake ricecar spos was made in china on the label in the back.
« Last Edit: Wed, 10 February 2010, 21:09:29 by elbowglue »
Offline elbowglue
« Reply #7 on: Wed, 10 February 2010, 21:18:55 »
Quote from: ripster;157700
Didjamatics will be the most interesting one to watch.  Shipping to Korea???
If his goes for a high price I'm totally hocking mine on ebay and will prominently feature "WILL SHIP TO KOREA"
Offline whininggit
« Reply #8 on: Thu, 11 February 2010, 04:09:32 »
These have that 'G86'-look to the keys, which they call ATK, but essentially the tops are 20% larger than average and are usually found on the desktop Cymotion boards, as well as some POS boards. They are just rubber dome, but quite nice rubber domes at that (albeit cheap).
I think it's safe to assume that all G86 are rubber dome unless stated otherwise. I wonder if those earlier boards that turned up on eBay were a special order of some sort - really G80-series boards but with a G86 sticker applied for whatever reason.
« Last Edit: Thu, 11 February 2010, 04:20:34 by whininggit »
Cherry G80-3000LSCGB-2 (modded to Cherry MX Browns) (main) | Cherry G84-4100 (Cherry ML) | Compaq MX-11800 (modded to Cherry MX Blue) | Dell AT101W (Alps Black) | IBM Model M 1391406 (Buckling Spring) | Matias Tactile Pro (1.0) (Alps) | SGI AT-101 (Alps w/Dampers) | Black Alpsulator (XM Alps-type)
Offline itlnstln
« Reply #9 on: Thu, 11 February 2010, 07:34:14 »
Pay no attention to the model number.  Look at the Article number.  That will tell you if it is an MX or not.  A missing article number would indicate rubber dome; a true G86-XXXX.
Offline didjamatic
« Reply #10 on: Thu, 11 February 2010, 08:10:40 »
Haha, I thought it was ironic that people in Asian countries have been contacting me about keyboards when so many in the US want keyboards from their region.
Offline elbowglue
« Reply #11 on: Sat, 17 April 2010, 22:22:27 »
Another SPOS on ebay..
http://cgi.ebay.com/Cherry-POS-Keyboard-with-Magnetic-Card-Reader_W0QQitemZ270565155771QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3efef0a3bb#ht_2085wt_940
I asked the seller, looks like this one is the rubber dome variety.  Pictured is the brown cherry version, but the actual item is a "fake ricercar spos"
