Author Topic: Cherry Brown Clickey? Bwah ha ha  (Read 5245 times)
Offline ricercar
  • mostly abides
« on: Thu, 11 February 2010, 15:34:06 »
« Last Edit: Thu, 11 February 2010, 15:57:26 by ricercar »
Offline itlnstln
« Reply #1 on: Thu, 11 February 2010, 15:34:57 »
Nice.
  • Live long and prosper
« Reply #2 on: Thu, 11 February 2010, 15:43:58 »
My Cherry Brown keyboard isnt clicky at all... IBM's are the best clicky keyboards ever...
tp thread is tp thread
Offline ch_123
« Reply #3 on: Thu, 11 February 2010, 15:45:44 »
On eBay, click = not rubber dome. In some cases it means rubber dome too. Nothing new really...
Offline Mental Hobbit
« Reply #4 on: Thu, 11 February 2010, 15:48:18 »
Clickiness lies in the ear of the listener.
Typing on blues.
Offline ch_123
« Reply #5 on: Thu, 11 February 2010, 15:51:06 »
Or greed of the seller.
Offline bigpook
« Reply #6 on: Thu, 11 February 2010, 18:58:59 »
outside of this forum; does anyone really know the difference?
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #7 on: Thu, 11 February 2010, 20:03:59 »
I know someone who calls his Microsoft Desktop what-ever-it-is-thousand "clicky". It made me so mad I was tempted to clobber him with a real clicky keyboard (as in one where the keys make a clicking sound).
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #8 on: Thu, 11 February 2010, 20:06:28 »
Quote from: microsoft windows;157886
I've had similar sensations, but you probably shouldn't go through with it.
You don't want a murder charge against you, and if you club someone with an M on the head, that's exactly what you'll have.
kishy.ca
Offline whininggit
« Reply #9 on: Fri, 12 February 2010, 06:12:00 »
What is the definition of 'clicky' though?
With Cherry MX switches, the main types are Blue, Brown and Black which are marketed as Clicky, Tactile and Linear respectively. But the Browns and Blacks, although not having a simulated click, will still produce a clicking sound, more than the typical rubber dome that most people will have been exposed to.
And you could argue that 'clicky' only applies to keyswitch technology where the click is intentionally created (e.g. white Alps with the click leaf, blue Cherry with the two-part stems) but then where does buckling spring come in? As far as I know, there is nothing explicitely put into BS to make them click, the click is just a byproduct of the technology, yet we still refer to them as clicky keyboards.
I'd be willing to bet that the majority of mechanical keyboards being typed on by the majority of people, will sound 'clicky' to them during normal typing. And I'm talking about normal, balanced people - people who don't care whether something is a click, a clack or a thock. People that don't spend hours swapping switches or desoldering their keyboards. People who don't have saved keyboard searches set up in eBay!
« Last Edit: Fri, 12 February 2010, 06:27:39 by whininggit »
Cherry G80-3000LSCGB-2 (modded to Cherry MX Browns) (main) | Cherry G84-4100 (Cherry ML) | Compaq MX-11800 (modded to Cherry MX Blue) | Dell AT101W (Alps Black) | IBM Model M 1391406 (Buckling Spring) | Matias Tactile Pro (1.0) (Alps) | SGI AT-101 (Alps w/Dampers) | Black Alpsulator (XM Alps-type)
Offline didjamatic
« Reply #10 on: Fri, 12 February 2010, 07:50:04 »
Quote from: whininggit;157929
...I'm talking about normal, balanced people - people who don't care whether something is a click, a clack or a thock. People that don't spend hours swapping switches or desoldering their keyboards. People who don't have saved keyboard searches set up in eBay!
ROFL!!!
Yes, I put "Clicky" in the subject as a keyword to show up in search results, and to many people they would consider a Cherry Brown board clicky if used side-by-side with a rubber dome.  Though I certainly know the difference and most of us do, the world at large doesn't know the intricacies of mechanical switches.
The switch characteristics are clarified in the auction and there is a photo of keycap removed, so that should remove all doubts for those who know what they are looking for.
Offline sethstorm
« Reply #11 on: Fri, 12 February 2010, 12:59:41 »
Quote from: kishy;157888
M, possibly.  It all depends on how good the frame is.  The Terminal M's feel like they'd break first, though.
XT Model F or Terminal F, definitely.  At the least, you have serious injury potential.
« Last Edit: Fri, 12 February 2010, 13:03:31 by sethstorm »
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #12 on: Fri, 12 February 2010, 13:10:47 »
Quote from: sethstorm;158010
eh, I dunno...the board would of course break, all the rivets would go everywhere, but in particular an old-style 122-key would probably kill someone (think of the thick metal plate, and hitting them with the thin front edge of the board aiming for their forehead or perhaps back of their neck).
Again, not that it's a good idea to do this...
kishy.ca
Offline trievalot
« Reply #13 on: Fri, 12 February 2010, 18:22:37 »
i have a iphone with a clicky keyboard :P
[SIGPIC]
Offline elservo
« Reply #14 on: Fri, 12 February 2010, 19:50:34 »
Yeah, I would always include "Clicky" in the title because that's a good search string to utilize.
When searching for stuff, I always try misspellings.  So easy to find cheap stuff that way.
Majestouch Tactile Click (Work)
AEKII(Home)
Offline elbowglue
« Reply #15 on: Fri, 12 February 2010, 23:17:33 »
Bah $74 + shipping for this?  It's cheaper new on dell small business!
Ohwell.  Nice sales didj!
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
