Author Topic: Anybody using trik 1.2 with success ?  (Read 2266 times)
Offline Yuuki
« on: Mon, 27 March 2017, 03:44:51 »
Hello,
I plan to use a trik 1.2 pcb and solder some zealios 65 plate mounted on it.
But I read here and there than the software side seems to be difficult.
For starter, I couldn't download the tools (pcb control program for example) from the red line website : http://j61218k2h.wixsite.com/redline/pds
So I wonder, should I buy a Nerd pcb instead ? (It's compatible with a LZ-FE case right ?)
Offline meiosis
  • Time
Re: Anybody using trik 1.2 with success ?
« Reply #1 on: Mon, 27 March 2017, 03:49:00 »
tx87 and a87 and nerd are all compatible although clearance space I heard is different depending on some.
Keyboards:
Aripeko TKL
Offline Yuuki
« Reply #2 on: Mon, 27 March 2017, 04:00:31 »
Thanks for your answer.
Btw it's for a WKL case. Does it change anything for the pcb ? That's what you mean by "clearance space" ?
Offline meiosis
  • Time
« Reply #3 on: Mon, 27 March 2017, 04:02:00 »
some of the pcbs (think nerd) are wider so there isn't enough room around the case if it's something a bit more compact.
Keyboards:
Aripeko TKL
Offline Yuuki
« Reply #4 on: Mon, 27 March 2017, 04:16:02 »
So you say that nerd wont fit in the lz fe case ? (sorry I'm not sure I undesrstand)
Offline meiosis
  • Time
« Reply #5 on: Mon, 27 March 2017, 04:32:23 »
I think it should I had an lzfe before I am talking about how much room there is between the PCB and the sides of the case
Keyboards:
Aripeko TKL
Offline Yuuki
« Reply #6 on: Mon, 27 March 2017, 04:43:12 »
According to Gon's website, it should fit yes (usb only version) :
GON NS NerD Crystal TKL(USB/Wireless Combo)
GON NS NerD TKL(USB Only)
GON NS 87, A87, LZ(USB Only)
The pcb doesn't come with a plate I guess ?
Offline Yuuki
« Reply #7 on: Tue, 28 March 2017, 07:50:05 »
little bump
- Does b87 pcb from winkeyless.kr works for a LZ FE case ?
- Where can I get a plate for this ?
Best regards
