Author Topic: VA68 Case and AEK?  (Read 2706 times)
Offline _rubik
VA68 Case and AEK?
« on: Tue, 28 March 2017, 23:51:22 »
I've seen murmurings from old posts and imgur pictures. It seems like the VA68 Case can fit an AEK bottom row nicely. What's the scoop here? Has anyone built one?
Offline Blazestorm
Re: VA68 Case and AEK?
« Reply #1 on: Fri, 31 March 2017, 16:54:41 »
https://www.reddit.com/r/MechanicalKeyboards/comments/61tjsr/va68m_aek_edition/
I bought one built by another member. /u/ca178858 has built PCBs and Plates that are compatible, then you can buy a VA68M kit (w/ Aluminum case) off Taobao for about $80-90
So it requires a custom plate (for the Alps stabilizers and Alps switch cut-outs), as well as the custom PCB (for Alps pins).
Offline _rubik
« Reply #2 on: Sun, 02 April 2017, 23:05:41 »
Could you elaborate on the PCB. I haven't seen one circulating. Does someone here have the design files, or was there an old GB.
Offline Blazestorm
« Reply #3 on: Sun, 02 April 2017, 23:16:14 »
The member /u/ca178858 on reddit designs/builds them. I don't think he's sharing the files yet.
Here's where he is selling his old stock, but I know he's doing another run soon.
He doesn't do GBs, just orders stock and buys more when it runs low.
« Last Edit: Sun, 02 April 2017, 23:20:03 by Blazestorm »
