Author Topic: Painting RedScarf III question  (Read 1549 times)
Offline mankeroo
« on: Fri, 31 March 2017, 10:51:43 »
I've got a RedScarf III kit on its way to me shortly. This will be my first kit that I'm assembling. When I ordered the kit, I got the black case option because I wasn't sure what caps I wanted to pair with it, and I wanted flexibility in that regard. However, as soon as Dasher was announced, I knew that's what I wanted on this board, so I got in on that drop.
My questions are:
  • What is the best way to turn the plastic from the RedScarf kit from black to a blue that would look nice with Dasher? Carefully masking and spray painting? Some other process entirely?
  • Should I do it before I assemble the board or can I go ahead and assemble it and use it while I wait a few months for Dasher to be delivered?
  • Depending on whatever process y'all recommend, any tips on finding the perfect blue/color?
  • Any tips in general for a first time assembler
Re: Painting RedScarf III question
« Reply #1 on: Fri, 31 March 2017, 13:22:18 »
masking and painting, but only if it's a plastic case
if it's alu it's a bit more complicated and i would say just suck it up and use whatever color you have
before would be easiest so you wouldn't have to take the PCB out
but it really doesn't matter
god bless pantone
god bless paint chips
read my LZ build log thread, there's a link in my signature
building a keyboard is really easy, just make sure you do your reading
Offline mankeroo
« Reply #2 on: Fri, 31 March 2017, 17:47:49 »
Thanks for the reply! It's definitely aluminium. Guess I'll see how she looks with the caps before going down that road.
« Reply #3 on: Fri, 31 March 2017, 17:53:24 »
then definitely don't paint it
aluminum is much better anodized
pay to have the board re anodized if you really think you need it, it'll look better
