Author Topic: Cherry stabilizers problem  (Read 2814 times)
Offline 27.9.2016
« on: Sat, 01 April 2017, 15:39:37 »
Do you know how to fix this problem?
I use cherry mx blue switches
https://drive.google.com/open?id=0B-97zaXN-fZ9TjZfUkMtamRGaDQ
Offline kiwi99
  • that's a gnarly dookie
Re: Cherry stabilizers problem
« Reply #1 on: Sat, 01 April 2017, 15:53:51 »
I'm guessing this is a custom plate and this is an issue I ran into similarly, basically the stem of the stabilizer is being forced into the side of the stabilizer housing. To fix it I took a sharp knife and just shaved down a bit on the top lip of the housing then lubed them as much as I could.
Offline 3K
« Reply #2 on: Sat, 01 April 2017, 15:56:39 »
Are these stabs clipped? Clipping MIGHT fix this issue.
Offline 27.9.2016
« Reply #3 on: Sun, 02 April 2017, 08:30:04 »
It's working now. Problem was that I didn't cut enough deep  :)
https://drive.google.com/open?id=0B-97zaXN-fZ9TVFfNzVXOF9wWHM
