Author Topic: [GB] ACE-XT40 Group Buy(Shipping Complete)  (Read 62434 times)
Offline gnmar2723
Re: [GB] ACE-XT40 Group Buy(Invoicing)
« Reply #50 on: Sat, 15 April 2017, 12:25:21 »
Paid up! I'm super excited for this :D
Offline sandwich113
« Reply #51 on: Sun, 16 April 2017, 00:58:22 »
Invoice paid
It is a great expectation.
Offline ppp
  • KappaKeepoKoopa
« Reply #52 on: Mon, 17 April 2017, 07:53:07 »
paid and excited!!
Offline ibakey
« Reply #53 on: Mon, 17 April 2017, 21:50:24 »
Paid!!! =D
Offline ppp
  • KappaKeepoKoopa
« Reply #54 on: Tue, 25 April 2017, 07:37:12 »
Any updates? Has the order been  sent? :)
Offline Liam
« Reply #55 on: Tue, 25 April 2017, 21:51:18 »
Same question. It's been a while since it ended.
IBM Model M - Leopold 750r - Custom Numpad
Offline joshuaauger
« Reply #56 on: Wed, 26 April 2017, 07:27:02 »
Any updates?
Offline wangbwhz
« Reply #57 on: Thu, 27 April 2017, 12:27:22 »
Any updates?
We have placed the order with the factory, you can check your order on google sheet.
My Precious¬
Offline sandwich113
Re: [GB] ACE-XT40 Group Buy(Waiting for production)
« Reply #58 on: Sun, 30 April 2017, 05:35:10 »
Thanks!  :)
Could you show us the modified case design and the compatibility of the planck pcb?
Offline wangbwhz
« Reply #59 on: Tue, 02 May 2017, 10:10:58 »
Thanks!  :)
167487-0
just received from the designer. :thumb:
My Precious¬
Offline sandwich113
« Reply #60 on: Thu, 04 May 2017, 11:18:35 »
Thanks!  :)
Can you compare the installation of ACE-xt40 PCB and the installation of Planck PCB after CNC machining is done later?
Offline fatpolomanjr
« Reply #61 on: Sat, 06 May 2017, 19:07:27 »
I snuck into the group buy! Just in time before production. Black case and gray plate. This is going to rock.
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
Offline Danilo_dk
« Reply #62 on: Sun, 07 May 2017, 03:16:19 »
Count
84/128
Is this a typo? In the spreadsheet there are only 28 entries.
Offline wangbwhz
« Reply #63 on: Sun, 07 May 2017, 04:40:11 »
Count
84/128
This is because the orders from China are not included.
My Precious¬
Offline wangbwhz
« Reply #64 on: Sun, 07 May 2017, 04:45:20 »
Thanks!  :)
Once received the pic from the designer, i will upload it here.
« Last Edit: Sun, 07 May 2017, 08:34:40 by wangbwhz »
My Precious¬
Offline Ozymandias99
  • Uhhh I don't know what to put here so Hello There!
Re: [GB] ACE-XT40 Group Buy(In production)
« Reply #65 on: Sat, 13 May 2017, 06:12:44 »
This just occurred to me - will the case have a hole for the Planck PCB reset button?
Offline wangbwhz
« Reply #66 on: Sat, 13 May 2017, 06:58:33 »
Unfortunately the case does't have the hole for the reset button, you need to dissemble the case, for your convenience small wrench is provided in each set.
Hope this issue doesn't bother you so much.
My Precious¬
Offline Danilo_dk
« Reply #67 on: Sat, 13 May 2017, 08:44:20 »
No hole for the reset button shouldn't be much of an issue. Just put a RESET key in your keymap and use that instead.
« Reply #68 on: Sat, 13 May 2017, 14:14:39 »
Didn't know you could do that. Thanks!
Offline gnmar2723
« Reply #69 on: Sat, 27 May 2017, 22:38:00 »
Any new updates for us?  :)
Offline wangbwhz
« Reply #70 on: Sun, 28 May 2017, 05:51:50 »
Update: Everything is on schedule.Keyboards will be shipped out at the end of June, I will post some pictures later.
« Last Edit: Sun, 28 May 2017, 06:01:58 by wangbwhz »
My Precious¬
Offline sandwich113
« Reply #71 on: Sun, 28 May 2017, 09:22:51 »
Thanks for the good news!
Offline wangbwhz
« Reply #72 on: Wed, 31 May 2017, 02:03:04 »
Potato picture for black case.  Update: The case fits the olkb pcb well! :thumb:
169680-0
169682-1
169684-2
My Precious¬
Offline neon_tom
« Reply #73 on: Wed, 31 May 2017, 06:02:03 »
Wow, it looks great! Really excited to see these out in the wild fully built.
Offline Danilo_dk
« Reply #74 on: Wed, 31 May 2017, 09:00:28 »
So the Planck PCB fits in the case, but has the alignment of the switches with the plate been tested as well? I remember that the spacing between keys is slightly different from the standard on the Planck, and I want to be sure that I can use my PCB when I get this case.
The case looks real nice, though. I ordered a black one myself. Can't wait.
Offline gnmar2723
« Reply #75 on: Wed, 31 May 2017, 21:45:03 »
This is super awesome looking! Can't wait for the final thing  :thumb:
Offline wangbwhz
« Reply #76 on: Mon, 12 June 2017, 23:43:08 »
170730-0
170732-1
170734-2
170736-3
Update: Designer have assembled the keyboards with OLKB PCB, everything works well.
Estimated shipping time: end of June
« Last Edit: Tue, 13 June 2017, 00:46:49 by wangbwhz »
My Precious¬
Offline sandwich113
« Reply #77 on: Tue, 13 June 2017, 03:41:06 »
Super cool!
Thanks! wangbwhz
Offline Danilo_dk
« Reply #78 on: Tue, 13 June 2017, 05:09:37 »
Awesome. I'm definitely excited for this case. Will all the screws be gold like that?
Offline wangbwhz
« Reply #79 on: Tue, 13 June 2017, 06:44:28 »
yes for sure~
My Precious¬
Offline Danilo_dk
« Reply #80 on: Tue, 13 June 2017, 07:27:23 »
yes for sure~
Is there not an option to get black ones instead? Or can these sorts of screws easily be found in hardware stores?
Offline ppp
  • KappaKeepoKoopa
« Reply #81 on: Tue, 13 June 2017, 08:00:17 »
Definitely should be able to find one from a hw store
Offline Unforgivable
« Reply #82 on: Wed, 14 June 2017, 08:41:24 »
Really silly question, but will there be any extras available? Or maybe a Round 2 after this? :(
Offline Geckt
« Reply #83 on: Thu, 15 June 2017, 10:20:17 »
wow, the anodizing looks really nice and the red looks even better than on the prototype piece strangely.  :)
Offline Chiovatto
« Reply #84 on: Thu, 15 June 2017, 12:20:12 »
Probably not the best time to ask this but, can we consider to do a group buy just for the PCB(and maybe the plate also)?? Might be interesting since a lot of us would like to build a planck-stlye keyboard that can be shipped through China and (probably) does not that much with the shipping.
Offline climbalima
  • likes building stuff
« Reply #85 on: Wed, 21 June 2017, 00:22:01 »
There is a planck pcb on taobao. Dont have the link though.
Sent from my SM-G920V using Tapatalk
Offline ppp
  • KappaKeepoKoopa
« Reply #86 on: Mon, 26 June 2017, 11:00:43 »
Any updates? All the pictures look great! Are we still on schedule to be shipping fairly soon according to the previously mentioned "end of June" shipping time?
Offline Chiovatto
« Reply #87 on: Mon, 26 June 2017, 18:50:04 »
Funny enough I see that. There was not a link how to program it, at least not that I have seen. The PCB have a usb centered as well, so this a no go.
Offline climbalima
« Reply #88 on: Mon, 26 June 2017, 19:08:44 »
You could do a custom case with 2 plates. Im 99% sure it uses bootmapper though.
Offline wangbwhz
« Reply #89 on: Mon, 26 June 2017, 21:16:25 »
Most of keyboards are shipped out.
Tracking number: https://docs.google.com/spreadsheets/d/1SkXiPpYrCzQ9ASl0fEqTsEeU5qRSB1Q9RFWBceGrKqY/edit?usp=sharing
My Precious¬
Offline ibakey
Re: [GB] ACE-XT40 Group Buy(Shipping)
« Reply #90 on: Mon, 26 June 2017, 21:59:38 »
Thanks wang! im excited to receive it
Offline Geckt
« Reply #91 on: Mon, 26 June 2017, 22:29:23 »
@wangbwhz: TYVM, so stoked to see mine already in the local distro.  :thumb:
Offline sandwich113
« Reply #92 on: Mon, 26 June 2017, 23:07:31 »
I got it today!
Thanks for the fast shipping!
Offline ppp
  • KappaKeepoKoopa
« Reply #93 on: Tue, 27 June 2017, 00:10:10 »
Thanks! super excited.
Offline q1w2e3r4t5z
« Reply #94 on: Tue, 27 June 2017, 01:32:50 »
Would you terribly mind editing out clear names, please?
Offline Danilo_dk
« Reply #95 on: Tue, 27 June 2017, 02:12:32 »
I may be missing something, but where do I go to input the tracking number? Never mind. I found it, http://www.sf-express.com/hk/en/dynamic_functions/waybill/.
« Last Edit: Tue, 27 June 2017, 02:16:52 by Danilo_dk »
Offline wangbwhz
« Reply #96 on: Tue, 27 June 2017, 03:14:27 »
I have cleared name for you.  :thumb:
My Precious¬
Offline q1w2e3r4t5z
« Reply #97 on: Tue, 27 June 2017, 03:18:51 »
Thanks, might be good to at least shorten the last names of the rest, like just the first 2 letters or so?
Offline neon_tom
« Reply #98 on: Tue, 27 June 2017, 06:31:19 »
I agree with this. Or use forum names, which is a more common practice on public documents like this.
Offline Locnguyen1507
« Reply #99 on: Wed, 28 June 2017, 12:41:42 »
Hey guys, what a pity that i missed out this groupbuy....and i'm still waiting for the picture of the green one  :(
