Author Topic: gnamr2723's projects (just made a bleach shirt)  (Read 55623 times)
Offline gnmar2723
« on: Sun, 14 May 2017, 00:21:15 »
Heyo, just a little thread about any projects or modifications I am working on.
Finished projects:
The HADwood
Black Mesa bleach shirt
First Project: Wooden MX HHKB
Let's start things off with hhkb blockers I am making for my mx hhkb. Current state is very ugly -_-
Another problem with this build I'm having is how tight the case is. Whenever I hit backspace, it rubs on the edge. Hopefully a few minutes of concentration and a sharp chisel will fix that.
That is all for now since I have to let the glue dry for a few more days.
I'm pressing some thin wood veneers together in hopes to make a cool layered very similar to how skateboard decks look from the side. Both patterns are exactly the same; they're also symmetrical from top to bottom.
« Last Edit: Tue, 08 August 2017, 21:59:15 by gnmar2723 »
Offline TalkingTree
    • My projects
Re: gnamr2723's projects
« Reply #1 on: Sun, 14 May 2017, 03:18:27 »
That doesn't look like that much material to remove, perhaps you can do that with sand paper alone.
BTW, what wood is the case made out of? Maple?
Offline gnmar2723
« Reply #2 on: Sun, 14 May 2017, 10:29:45 »
It's just such a small spot that trying to run sandpaper there doesn't really do much. It's easier (for me at least) to use a sharp chisel in such a circumstance.
The wood is bamboo which makes it pretty easy to plane away too.
Offline TalkingTree
    • My projects
« Reply #3 on: Sun, 14 May 2017, 11:39:21 »
That bamboo case looks very nice. Did you make it yourself?
Offline gnmar2723
« Reply #4 on: Sun, 14 May 2017, 11:43:21 »
Got it from /u/lxkhn on reddit. His 60% cases are awesome.
Offline gnmar2723
« Reply #5 on: Sun, 14 May 2017, 13:49:35 »
Fixed up the inside edge of the case so keycaps no longer hit them when pressed.
I also took the wood out of the mold and started to smooth it down. Looking good so far, although I didn't add enough plies, so It won't be as wide as I had hoped. Maybe I can fill the gaps with some scraps...
It's maybe a 1/8th inch gap.
Offline gnmar2723
« Reply #6 on: Thu, 18 May 2017, 23:19:05 »
Alright, another update. I'm getting very close on the first blocker; I just have to knock down the height a little and we are golden. Also, anyone have any ideas what to do with the little gap between the north part of the blocker and right shift/function?
« Last Edit: Sat, 20 May 2017, 17:03:07 by gnmar2723 »
Offline gnmar2723
« Reply #7 on: Sat, 20 May 2017, 16:54:54 »
Finally finished what I'm calling, the HADwood (because it sounds like 'hard wood' said in a Boston accent, and the HAD obviously signifies the keycap layout)
« Last Edit: Sat, 20 May 2017, 17:04:37 by gnmar2723 »
Offline gnmar2723
Re: gnamr2723's projects [i am working on many things currently]
« Reply #8 on: Fri, 30 June 2017, 21:01:29 »
Ok long time no see.
Currently working on three different 60% keyboards.
Hopefully they will be done very soon!
Offline TalkingTree
    • My projects
« Reply #9 on: Sat, 01 July 2017, 08:41:42 »
Did you design the PCBs yourself?
Offline gnmar2723
« Reply #10 on: Sat, 01 July 2017, 11:29:01 »
Nope, just GH60 PCBs.
Offline gnmar2723
Re: gnamr2723's projects (just made a bleach shirt)
« Reply #11 on: Tue, 08 August 2017, 21:54:37 »
Today I made a Black Mesa bleach shirt! I didn't realize until now, but the colors even match geekhack  :))
Thinking about doing some more, but not sure what logos/designs I might like... :thinking:
Offline klaushouse
« Reply #12 on: Wed, 09 August 2017, 00:27:14 »
Gosh these make me miss my first compact, the Razer Tournament Edition. Really nice!
Offline AlexAtPanc
    • Panc Interactive
« Reply #13 on: Wed, 09 August 2017, 22:12:47 »
Bleach shirt is brilliant.
« Reply #14 on: Thu, 10 August 2017, 06:52:27 »
The shirt looks good. I can't do something like it because chlorine isn't sold over here any more.
Offline gnmar2723
« Reply #15 on: Thu, 10 August 2017, 20:04:28 »
Wait what? Why not?? Seems silly to me...
Offline Ruskie
« Reply #16 on: Mon, 20 November 2017, 09:54:50 »
It is very easy to make explosives or drugs out of Chlorine and the gas it emits. I would love to start a project like that! What method did you use to create such a defined shape with the bleach?
Ive got myself a beefy boi
-Alf F62PE
-PCB Mount ZealV2 67g
-GMK KA1953 "OG Classic Retro"
8 pounds of clack
Offline gnmar2723
« Reply #17 on: Thu, 23 November 2017, 20:43:34 »
Ahh I can see why it would be hard to get Chlorine bleach then.
The bleach shirts reddit is where I found out about making t-shirts like this! This guide specifically is what I followed and it worked out great for me!
