Author Topic: How can I unwatch locked thread?  (Read 10988 times)
Offline ChitownM2
« on: Sun, 02 April 2017, 11:46:18 »
I'd like to be able to remove threads that have been locked from my "watched" list and it doesn't seem like that is possible at the moment. Mainly these are IC threads that I'm following that turn into GB's.
It doesn't really make sense why threadstarter's decision to lock a thread should mean that it is permanently part of my personal watch list.
Offline Photoelectric
Re: How can I unwatch locked thread?
« Reply #1 on: Sun, 02 April 2017, 13:08:19 »
Watched Unread list only displays threads that have new posts since you last read them.  All you need to do is to click on the thread and read the last post, then go back to your watch list, and you'll see that the thread will no longer appear on the list.  Since the thread is locked, there won't be any more posts in it to make it reappear.
Do you not see "unwatch" option inside the thread at the top right?  (desktop browser)
« Last Edit: Sun, 02 April 2017, 13:12:15 by Photoelectric »
Offline ChitownM2
« Reply #2 on: Sun, 02 April 2017, 13:14:21 »
I want to remove it from my watch list completely, not just the from the unread topics portion.
Since there is no subscribe feature here that can be sorted, etc, I use the watched topics like a subscribe feature. Therefore I may go back to topics that don't have any new posts so I am constantly looking at my "all watched topics" page rather than just the unread one.
« Reply #3 on: Sun, 02 April 2017, 13:17:10 »
I edited my post above to add a screenshot.  Are you using a desktop version of the browser?  Please check inside the thread you want to unwatch, at the very top right (desktop browser or desktop view in a mobile browser).  Is there no "Unwatch" button?
« Reply #4 on: Sun, 02 April 2017, 13:22:14 »
I can't either, PE. Seems like a permissions thing.
« Reply #5 on: Sun, 02 April 2017, 13:25:54 »
Here is a previous thread with a potential solution
https://geekhack.org/index.php?topic=46649.0
A workaround is to go into the thread, copy the link from the notify button, paste it into the address bar, replace "action=notify;sa=on;" with "action=unwatch;", and hit enter  ;D
« Reply #6 on: Sun, 02 April 2017, 13:29:39 »
Thanks for the confirmation.  Yes, it does appear to be a permissions issue for different membergroups, because I see the "unwatch" button in locked threads.  I'll look into it.
« Reply #7 on: Sun, 02 April 2017, 13:38:44 »
hehe
good thing i remembered to keep all my permissions info from when i had mod powers
Offline ChitownM2
« Reply #8 on: Sun, 02 April 2017, 14:02:40 »
Correct there is no "Unwatch" button for locked threads. I can turn notifications on and off, but the unwatch button is totally missing.
Mine looks exactly the same.
Worked perfectly! Thank you for this.
This issue doesn't come up often enough that it's a big problem so the workaround is probably sufficient, but it should probably be stickied or something to make it easier to find. I did a search and never came across that previous thread.
