Author Topic: How to spot screw-in stabilizers?  (Read 3026 times)
Offline Philister
« on: Sun, 02 April 2017, 13:51:13 »
Do they have a distinct look and can be identified at a glance just by taking off a keycap or will I have to take it out of the case and look at the bottom of the PCB?
Re: How to spot screw-in stabilizers?
« Reply #1 on: Sun, 02 April 2017, 14:01:02 »
They have screws in them?
164666-0
image courtesy of a google search + mspaint
« Reply #2 on: Sun, 02 April 2017, 14:25:14 »
novel
Offline Philister
« Reply #3 on: Sun, 02 April 2017, 15:21:32 »
Thanks very much for taking the trouble! So the ends of the screws should always be visible under the keycaps...
