Author Topic: [SOLVED]Phantom keyboard ANSI 87 key configuration help Easy AVR  (Read 1686 times)
Offline eRadicatedZomBiE
  • It's OK, I'm A Doctor.
If this isn't the appropriate spot please let me know. I'm trying to get the ctrl+shift+esc shortcut to work along with the win+L shortcut and the shift+tab shortcut. I can't quite seem to get it. Does anyone have any ideas? it's probably something that I'm over looking.
I'm using Easy AVR keyboard to map my keys.
thanks for any help!
« Last Edit: Mon, 03 April 2017, 14:44:40 by eRadicatedZomBiE »
CM QFR | WASD V1 | Flico MJ2 LE Blue | Ducky 78 | Ducky DK9008G2 Pro LE  |Phantom |
Ergodox
My WTB Thread
Re: Phantom keyboard ANSI 87 key configuration help Easy AVR
« Reply #1 on: Mon, 03 April 2017, 14:43:39 »
Got it! You have to change the key mode from 'Normal' to 'Tap key' then assign the 'tap key' what ever key you'd like it to work with. Man that was bugging me!
Ergodox
My WTB Thread
Re: [SOLVED]Phantom keyboard ANSI 87 key configuration help Easy AVR
« Reply #2 on: Mon, 03 April 2017, 14:48:46 »
yay
