Author Topic: Keyboard recommendations for an office worker.  (Read 3713 times)
Offline Encabulator
« on: Tue, 04 April 2017, 09:31:47 »
My father works for a graphics company in an office with large cubicles.  I've been showing him my keyboards and hes developed an interest but his main concern with purchasing one is disturbing his neighbors.  Please send reccomendations that meet these requirements.
-Below 200 USD
-Somewhat quiet (Only slightly louder than a rubber dome)
-Heavy linear switch (Mx Black, Gateron black etc...)
-Numberpad (Nav cluster good but not needed.)
-Simple colors (No flashy bright colors)
-Sturdy feel, the keyboard is staying in one place so weight isn't an issue.
Right now I'm actually considering the Topre Type Heaven but I'm not sure if he would like the keyfeel and its pretty expensive to just test out.
The CM TK Stealth would be great but it only comes in reds for linear which is far too light for his taste. I only have so much experience with mechanical keyboards so I was hoping that some of you would possibly have a keyboard that meets most of these requirements. Thanks as usual!  :thumb:
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline kmba
  • Formerly tameone
keyboards.
Re: Keyboard recommendations for an office worker.
« Reply #2 on: Tue, 04 April 2017, 09:43:30 »
I can second the Leopold recommendation, great board.
You might also consider getting him either one of fohat.digs rubber pieces (https://geekhack.org/index.php?topic=59308.0) or some other dampening material to put between the keyboard and his desk.
This will dampen the sound a little more and give a firmer base so it won't slide.
« Last Edit: Tue, 04 April 2017, 10:29:14 by SpAmRaY »
Offline drakche
« Reply #3 on: Tue, 04 April 2017, 10:38:39 »
If you want a cheap, quite daily driver have a look at Plum EC.
You have it as 75, 84, 87 and 108 keys forms, w/ or w/o RGB.
Imho, it's much better than MX board I've used and the coworkers are finally calm about my clacking. :D
Offline DRAZAH
  • Hype-S
« Reply #4 on: Tue, 04 April 2017, 11:33:09 »
Get a Topre and hypersphere and lube it. I brought my stock RealForce 87U 55g to work today and its still pretty loud. I daily drive a modded HHKB that is near silent and is really the only keyboard I feel comfortable using in an office setting.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #5 on: Tue, 04 April 2017, 13:28:32 »
^ Third on this.
Normally I'd recommend Topre Type Heaven for office but in your case this the Leopold will match your switch preference better.
MX Black is also pretty quiet for Cherry switch.
Offline opensecret
  • 公开的秘密
« Reply #6 on: Tue, 04 April 2017, 13:29:06 »
The Plum is a good keyboard that's well within the $200 budget, but it's subtly tactile rather than linear, and AFAIK 45g is the heaviest available switch.
You can sometimes find a used Realforce on eBay for under $200.  Still tactile, but a great board.
IBM Model M |Matias Mini Quiet Pro|Plum 84EC-S|RealForce 103U-UW & 87U-UW|Omnikey Ultra T| 2 Omnikey Ultras| WASD V2| Xmit Hall Effect|
« Reply #7 on: Tue, 04 April 2017, 16:21:09 »
**** the plum, it's ****
get the leopold or a filco
Offline drakche
« Reply #8 on: Tue, 04 April 2017, 16:27:35 »
you can easily do a dome swap mod for 20ish $.
to get a 55g or even 62g weights.
Offline Tactile
« Reply #9 on: Tue, 04 April 2017, 18:26:55 »
Well, I'm going to be different and suggest a Matias Quiet Pro. Yes, it's tactile not linear but it's a really nice typing feel quite unlike Cherry MX "tactile" switches. And it is very quiet.
REΛLFORCE
Offline pixelpusher
« Reply #10 on: Tue, 04 April 2017, 18:35:04 »
Of course anyMX black switch is just as loud as browns or reds.  I say go with blacks and dampen them (which I hate the feel of), try mx silent (very quiet but a bit mushy and scratchy as hell), or go the Matias route.
Cant do topre bc you said heavy.  I hated my topre (novatouch) bc it was too light
Offline opensecret
  • 公开的秘密
« Reply #11 on: Tue, 04 April 2017, 19:50:55 »
There are a lot of possible ways to fill in your asterisks, but "Get the Plum, it's magnificent" probably isn't what you had in mind.
I have a Plum84 that I like; it's particularly useful when I want something quiet, light and easily portable.  The switches aren't in the same league with genuine Topre, but at roughly half the cost of a Realforce, it's a good buy.
« Reply #12 on: Tue, 04 April 2017, 19:52:14 »
mans does not like plum
mx is better for the price
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #13 on: Tue, 04 April 2017, 21:37:27 »
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2049
this
or Filco: https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1818
if you want topre switch, find an used RealForce (since your budget is limited).
I have tried Topre Type Heaven and I don't like it (maybe I don't like topre switch in general, not just Topre Type Heaven)
Offline svatech
« Reply #14 on: Tue, 04 April 2017, 22:59:37 »
Get dell at101. Remove tactile leaves
Sent from my SCH-I545 using Tapatalk
Offline svatech
« Reply #15 on: Tue, 04 April 2017, 23:00:18 »
Get dell At101. Remove tactile leaves
