Author Topic: Where to order screws and nuts online in europe ?  (Read 5290 times)
Offline dustpuppy
« on: Fri, 07 April 2017, 09:48:27 »
A fellow redditor is asking me for help on how to build a stainless steel atreus. I went through that process myself and documented the CAD files and parts I needed here: https://github.com/technomancy/atreus/tree/master/case/lasergist_steel_plates
particularly, we're curious about where to order screws in europe ? Mcmaster doesn't ship to europe.
we need this:
    8x 14mm long M3 screws, low profile head https://www.mcmaster.com/#93070A071
    8x 8mm long M3 hex nuts https://www.mcmaster.com/#94868A603
    8x M3 small hex nuts https://www.mcmaster.com/#98676A100
Thanks for any suggestions !
Offline 3K
Re: Where to order screws and nuts online in europe ?
« Reply #1 on: Fri, 07 April 2017, 15:42:14 »
Usually there should be at least one national shop, which provides the hardware you are asking for.
This site would be an option: http://www.mercateo.com/kw/distanzmuffe(20)m3/distanzmuffe_m3.html
About shipping outside of Germany (where they are based) they say, that one would need to request this with a special form.
I guess you could just google, to find something in your country.
Offline madhias
  • BS TORPE
    • Madhias' Flickr
« Reply #2 on: Fri, 07 April 2017, 15:46:29 »
I ordered a while ago here some screws: https://www.screwsandmore.de/
Maybe they have what you need!
« Reply #3 on: Fri, 07 April 2017, 15:51:55 »
Which country are you in? Which city?
Here in Sweden the go-to place is Sifvert Skruv. Often a little more expensive but they have everything. I don't think they export.
« Last Edit: Sun, 09 April 2017, 10:33:39 by Findecanor »
Offline qbits
« Reply #4 on: Sat, 08 April 2017, 11:42:45 »
That's great thanks, I am in Sweden, if they have *everything* I might find these damn screws there.
I will let you know.
Offline qbits
« Reply #5 on: Sat, 08 April 2017, 12:13:25 »
They don't seem to have these screws either. Only 12mm in M3 and not black-oxide.
The closest I can find is https://eu.shop.bossard.com/ie/en/8229/socket-products/hex-socket-head-cap-screws/bn-16_hex-socket-head-cap-screws-with-low-head-partially-fully-threaded but not in 14mm  :(
Offline Data
« Reply #6 on: Sat, 08 April 2017, 20:02:12 »
Have you tried AliExpress or one of the other Chinese exporters?  They might be a last resort option.
Offline qbits
« Reply #7 on: Sun, 09 April 2017, 03:44:18 »
Yep I did and no luck either. I ll check with dustpuppy if 12mm or 16mm would do and order from the one I mentioned earlier I think but the order minimum is 100 pieces, which  is a bit too much I think  :eek:.
« Last Edit: Sun, 09 April 2017, 03:48:22 by qbits »
Offline traktor
« Reply #8 on: Sun, 09 April 2017, 09:34:15 »
An alternative would be to use a threaded standoff with (shorter) screws on each side? Or just regular plain vanilla screws  :p
Edit: meant standoff, not nut
Offline Data
« Reply #9 on: Mon, 10 April 2017, 06:26:57 »
« Reply #10 on: Mon, 10 April 2017, 08:53:09 »
Longer M3 bolts could be cut shorter with a Dremel cutting wheel, deburred and then blackened with "Gun blue" liquid from a gun store.
I have done both of these things but not to re-blacken black bolts, and I have Gun Blue on hand for other things, otherwise it would not be cost-effective.
« Last Edit: Mon, 10 April 2017, 08:54:52 by Findecanor »
